Ir para o conteúdo principal
TI-84 Plus Silver Edition Main Battery Replacement
  1. TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: passo 1, imagem 1 %32 TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: passo 1, imagem 2 %32 TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: passo 1, imagem 3 %32
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
    Pergunte ao FixBot
    Comentar
  2. TI-84 Plus Silver Edition Main Battery Replacement: passo 2, imagem 1 %32
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 11-34, Amido Fall 2013 Membro de Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Membros
Autoria de 8 guias
1Comentário do guia
cool i can math now thank
Thomas Maloney - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 10,857
