Ir para o conteúdo principal
TECHUP Bluetooth Speaker Motherboard Replacement
O que você precisa
  1. TECHUP Bluetooth Speaker Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Pry the foam buffer from the speaker using a nylon spudger.
    • You will need to re-apply adhesive if you want to reattach this foam after removing it.
  2. TECHUP Bluetooth Speaker Motherboard Replacement: passo 2, imagem 1 %32 TECHUP Bluetooth Speaker Motherboard Replacement: passo 2, imagem 2 %32 TECHUP Bluetooth Speaker Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the two bottom screws using a Phillips #0 screwdriver.
  3. TECHUP Bluetooth Speaker Motherboard Replacement: passo 3, imagem 1 %32 TECHUP Bluetooth Speaker Motherboard Replacement: passo 3, imagem 2 %32
    • Pull the plastic casing away from the speaker.
    • You may have to twist-and-pull to remove it.
  4. TECHUP Bluetooth Speaker Motherboard Replacement: passo 4, imagem 1 %32 TECHUP Bluetooth Speaker Motherboard Replacement: passo 4, imagem 2 %32
    • Desolder the two battery wires from the motherboard.
    • Because you are dealing with battery connections, be aware of the shock hazard.
  5. TECHUP Bluetooth Speaker Motherboard Replacement: passo 5, imagem 1 %32 TECHUP Bluetooth Speaker Motherboard Replacement: passo 5, imagem 2 %32
    • Desolder the two speaker wires from the motherboard.
  6. TECHUP Bluetooth Speaker Motherboard Replacement: passo 6, imagem 1 %32
    • Grasp the motherboard and pull it from the encasement.
    • Take care to not rip the wires as you pull the motherboard out, as they may catch in the grooves on the motherboard.
  7. TECHUP Bluetooth Speaker Motherboard Replacement: passo 7, imagem 1 %32
    • Pry the battery from the motherboard using a nylon spudger.
    • You may have to apply significant force to the motherboard to remove the battery.
    • Always use an ESD-safe tool, such as a nylon spudger, when working with batteries. Metal tools can puncture an unprotected battery, potentially causing a fire.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 94
Duração total: 993
