Introdução
The motherboard is an essential part of the device because it contains several sockets and slots, which holds and allows all the circuitry in the device, to connect to other various components throughout the device. Because the motherboard plays such a crucial role, this guide was created to provide step by step instructions to assist the user in replacing the motherboard.
O que você precisa
Flip your device upside down so the battery cover is facing upwards.
Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
Turn over the device so the bottom is facing up. Remove the screws of the battery cover using the iFixit TR7 screwdriver.
Remove the battery cover by pulling up where the screws should go.
Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
Remove the battery cover.
