Ir para o conteúdo principal
TDK Life on Record Trek Max A34 Buttons Replacement
O que você precisa
  1. TDK Life on Record Trek Max A34 Buttons Replacement, Battery: passo 1, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement, Battery: passo 1, imagem 2 %32
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Buttons Replacement: passo 2, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 2, imagem 2 %32
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Buttons Replacement: passo 3, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 3, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 3, imagem 3 %32
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Buttons Replacement: passo 4, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 4, imagem 2 %32
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Buttons Replacement: passo 5, imagem 1 %32
    • The battery is now separated from the device and may be replaced with a new battery.
  6. TDK Life on Record Trek Max A34 Buttons Replacement, Large Speaker: passo 6, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement, Large Speaker: passo 6, imagem 2 %32
    • Turn over the device so the bottom is facing up. Remove the screws of the battery cover using the iFixit TR7 screwdriver.
    • Remove the battery cover by pulling up where the screws should go.
  7. TDK Life on Record Trek Max A34 Buttons Replacement: passo 7, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 7, imagem 2 %32
    • Carefully unplug and remove the battery.
    • Use the metal spudger to pry off the rubber bumpers from the bottom of the speaker.
  8. TDK Life on Record Trek Max A34 Buttons Replacement: passo 8, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 8, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 8, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the screws that were underneath the rubber bumpers.
    • Remove the battery holder. Be sure to thread the exposed wires through the hole within the holder.
  9. TDK Life on Record Trek Max A34 Buttons Replacement: passo 9, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 9, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 9, imagem 3 %32
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it more easily.
  10. TDK Life on Record Trek Max A34 Buttons Replacement: passo 10, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 10, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 10, imagem 3 %32
    • Turn the speaker back upright. Use the metal spudger to pry up the rubber cover to reveal the buttons underneath.
  11. TDK Life on Record Trek Max A34 Buttons Replacement: passo 11, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 11, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the screws that hold the top cover in place.
    • Remove the top cover.
  12. TDK Life on Record Trek Max A34 Buttons Replacement: passo 12, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 12, imagem 2 %32
    • On the backside of the device, remove the screws using the Phillips #0 screwdriver.
    • Only the screws on the backside are needed to hold the frame together. Do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  13. TDK Life on Record Trek Max A34 Buttons Replacement: passo 13, imagem 1 %32
    • Within the device, there is a single cable connecting the large speaker to the motherboard. Unplug this cable.
  14. TDK Life on Record Trek Max A34 Buttons Replacement: passo 14, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 14, imagem 2 %32
    • On the front of the device, use the Phillips #0 screwdriver to remove the four screws holding the speaker in.
    • Once the screws are removed, you are able to push the speaker out from behind.
  15. TDK Life on Record Trek Max A34 Buttons Replacement, Small Speaker: passo 15, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement, Small Speaker: passo 15, imagem 2 %32
    • Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
    • Remove the battery cover.
  16. TDK Life on Record Trek Max A34 Buttons Replacement: passo 16, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 16, imagem 2 %32
    • Unplug and remove the battery.
    • Use a metal spudger to pry off the rubber padding.
  17. TDK Life on Record Trek Max A34 Buttons Replacement: passo 17, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 17, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 17, imagem 3 %32
    • Use a J00 screwdriver to unscrew the screws that are under the rubber pads.
    • Remove the battery holder and be sure to thread the wires through the hole within the part.
  18. TDK Life on Record Trek Max A34 Buttons Replacement: passo 18, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 18, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 18, imagem 3 %32
    • You may need to move the metal spudger along the edge of the screen to remove it easier.
  19. TDK Life on Record Trek Max A34 Buttons Replacement: passo 19, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 19, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 19, imagem 3 %32
    • Use the a metal spudger to pry up the rubber cover on the top surface of the device.
    • Peel off the rubber cover to reveal the buttons and screws underneath.
  20. TDK Life on Record Trek Max A34 Buttons Replacement: passo 20, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 20, imagem 2 %32
    • Use a J00 screwdriver to unscrew the screws that hold the top cover in place.
  21. TDK Life on Record Trek Max A34 Buttons Replacement: passo 21, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 21, imagem 2 %32
    • On the backside of the device, unscrew the case screws with a J00 screwdriver.
    • Only the screws on the backside are needed to hold the frame together, do not remove screws on the front.
  22. TDK Life on Record Trek Max A34 Buttons Replacement: passo 22, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 22, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement: passo 22, imagem 3 %32
    • The following steps can be applied to either the left or the right speaker.
    • Use a J00 screwdriver to unscrew the four screws that secure the speaker.
    • The speaker should fall out naturally. If the speaker is stuck, use a plastic opening tool or a metal spudger to gently lift it out.
    • Desolder the black and red speaker wires.
    • Review the Desolder guide if you are unfamiliar with soldering.
  23. TDK Life on Record Trek Max A34 Buttons Replacement, Motherboard: passo 23, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement, Motherboard: passo 23, imagem 2 %32 TDK Life on Record Trek Max A34 Buttons Replacement, Motherboard: passo 23, imagem 3 %32
    • Carefully detach the 4 white rectangular clips from the motherboard.
  24. TDK Life on Record Trek Max A34 Buttons Replacement: passo 24, imagem 1 %32
    • Carefully remove the motherboard from the device.
  25. TDK Life on Record Trek Max A34 Buttons Replacement, Buttons: passo 25, imagem 1 %32 TDK Life on Record Trek Max A34 Buttons Replacement, Buttons: passo 25, imagem 2 %32
    • Once the soldering iron is heated, carefully place the iron onto the connection point of the button.
    • With a steady hand, hold the soldering iron in place until the metal is slightly melted.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections guide.
  26. TDK Life on Record Trek Max A34 Buttons Replacement: passo 26, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to remove the buttons.
    • Repeat the previous step for multiple buttons.
Conclusão
Marilyn Ho
Membro desde: 11/04/19
211 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Harley Fall 2019 Membro de IUPUI, Team S1-G3, Harley Fall 2019
IUPUI-HARLEY-F19S1G3
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 367
