Ir para o conteúdo principal
System x3650 CPU and Memory Replacement
O que você precisa
  1. System x3650 CPU and Memory Replacement, CPU and Memory: passo 1, imagem 1 %32 System x3650 CPU and Memory Replacement, CPU and Memory: passo 1, imagem 2 %32
    • Make sure that you have unplugged the power cable before servicing.
    • Pull the latch on the top cover up.
    • Slide the cover out.
    Pergunte ao FixBot
  2. System x3650 CPU and Memory Replacement: passo 2, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 2, imagem 2 %32 System x3650 CPU and Memory Replacement: passo 2, imagem 3 %32
    • Press the two latches on the riser card assembly, indicated by blue arrows and outlines.
    • Slowly take the the riser card assembly out.
    • Doing so will allow you to remove the white plastic airflow guides.
    • This will provide access to the computer parts that you want to replace.
    Pergunte ao FixBot
  3. System x3650 CPU and Memory Replacement: passo 3, imagem 1 %32
    • Move the heat sink bracket lever to the open position and remove the heat sink.
    • This will provide access to the processor.
    Pergunte ao FixBot
  4. System x3650 CPU and Memory Replacement: passo 4, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 4, imagem 2 %32
    • Open the CPU retention bracket lever.
    • Remove the old processor from the socket.
    Pergunte ao FixBot
  5. System x3650 CPU and Memory Replacement: passo 5, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 5, imagem 2 %32
    • Remove the old RAM if it is being replaced.
    • Unfasten the clamps on both ends of the slot.
    • Take out the memory module.
    Pergunte ao FixBot
  6. System x3650 CPU and Memory Replacement: passo 6, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 6, imagem 2 %32
    • Insert the new memory modules into the empty RAM slots securely.
    • The clamps on both ends of the slot should click into place.
    • See this link for the DIMM installation sequence.
    Pergunte ao FixBot
  7. System x3650 CPU and Memory Replacement: passo 7, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 7, imagem 2 %32 System x3650 CPU and Memory Replacement: passo 7, imagem 3 %32
    • Insert new CPU into socket.
    • Ensure that the CPU chip is positioned correctly (i.e. its marked corner is facing bottom left).
    • Apply thermal paste to the top of the processor if necessary.
    • Close the CPU retention bracket lever.
    • An insecure or improper placement can damage a CPU or the socket pinout.
    Pergunte ao FixBot
  8. System x3650 CPU and Memory Replacement: passo 8, imagem 1 %32
    • Place the heat sink on top of the CPU.
    • Move the heat sink bracket lever to closed position.
    Pergunte ao FixBot
  9. System x3650 CPU and Memory Replacement: passo 9, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 9, imagem 2 %32 System x3650 CPU and Memory Replacement: passo 9, imagem 3 %32
    • If you need to add a second processor, move the heat sink bracket lever to open position.
    • Take out the white plastic cover on the second socket.
    • Repeat steps 7 and 8 for the second CPU/socket (insert a CPU and a heat sink).
    Pergunte ao FixBot
  10. System x3650 CPU and Memory Replacement: passo 10, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 10, imagem 2 %32 System x3650 CPU and Memory Replacement: passo 10, imagem 3 %32
    • Insert the plastic airflow guides back in their places.
    • Insert the riser card assembly, pushing it into its slot.
    Pergunte ao FixBot
  11. System x3650 CPU and Memory Replacement: passo 11, imagem 1 %32 System x3650 CPU and Memory Replacement: passo 11, imagem 2 %32
    • Slide the top cover in place firmly.
    • Ensure that the latch is in the down position.
    Pergunte ao FixBot
Conclusão
Follow this guide to replace or upgrade CPU and memory on IBM System x3650. Up to 2 processors can be installed. Up to 48 GB of RAM can be installed.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 98
Ao todo: 3,361
