Ir para o conteúdo principal
Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement
O que você precisa
  1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: passo 1, imagem 1 %32 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: passo 1, imagem 2 %32 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: passo 1, imagem 3 %32
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: passo 2, imagem 1 %32
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: passo 3, imagem 1 %32
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: passo 4, imagem 1 %32 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: passo 4, imagem 2 %32
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
    • Release the four camera cable connections on the motherboard.
  5. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: passo 5, imagem 1 %32
    • Facing the back of the motherboard, remove the two 2.0 mm Phillips #0 screws connecting the camera to the motherboard.
Conclusão
Um comentário
is there a place i can buy a replacement lens for my swann security camera please
sn 10050062001244
Sonny Jobe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 1,115
