Ir para o conteúdo principal
Swann Wi-Fi Indoor Security Camera SD Card Replacement
O que você precisa
  1. Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: passo 1, imagem 1 %32 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: passo 1, imagem 2 %32 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: passo 1, imagem 3 %32
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera SD Card Replacement: passo 2, imagem 1 %32
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera SD Card Replacement: passo 3, imagem 1 %32
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: passo 4, imagem 1 %32 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: passo 4, imagem 2 %32 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: passo 4, imagem 3 %32
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
  5. Swann Wi-Fi Indoor Security Camera SD Card Replacement: passo 5, imagem 1 %32
    • With the motherboard removed, flip it over and remove the SD card by pushing in the SD card, releasing it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 36
Duração total: 1,289
