Ir para o conteúdo principal
Swagtron T3 Wheel Replacement
O que você precisa
    1. Swagtron T3 Wheel Replacement, Cover: passo 1, imagem 1 %32 Swagtron T3 Wheel Replacement, Cover: passo 1, imagem 2 %32
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      Pergunte ao FixBot
      Comentar
    2. Swagtron T3 Wheel Replacement: passo 2, imagem 1 %32 Swagtron T3 Wheel Replacement: passo 2, imagem 2 %32 Swagtron T3 Wheel Replacement: passo 2, imagem 3 %32
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      Pergunte ao FixBot
      Comentar
    1. Swagtron T3 Wheel Replacement, Wheel: passo 3, imagem 1 %32
      • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
      • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
      Pergunte ao FixBot
      Comentar
    2. Swagtron T3 Wheel Replacement: passo 4, imagem 1 %32 Swagtron T3 Wheel Replacement: passo 4, imagem 2 %32
      • Pull the wheel off of its base.
      • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S13-G3, Forte Spring 2017 Membro de Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Membros
Autoria de 12 guias
3Comentários do guia
Hi,
my girl Swagtron T6 wheel is flat. Probably it is a nail hole. We are faraway from US, so I have to do it by myself. Can I get the wheel out for tire repairing?
Can you help me please?
Thanks
Susana Arzuaga - Responder Compartilhar
Can't the wheel off
Christopher Primo - Responder Compartilhar
I have a T6 Swagtron and I am struggling to get the wheel off. Are these magnets really that strong? It feels like there is something else holding the wheel in place. I tried prying it but doesn’t seem like its doing enough.
photostudiomilk - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 4,733
