Ir para o conteúdo principal
Swagtron T3 Battery Replacement
O que você precisa
    1. Swagtron T3 Battery Replacement, Cover: passo 1, imagem 1 %32 Swagtron T3 Battery Replacement, Cover: passo 1, imagem 2 %32
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      Pergunte ao FixBot
      Comentar
    2. Swagtron T3 Battery Replacement: passo 2, imagem 1 %32 Swagtron T3 Battery Replacement: passo 2, imagem 2 %32 Swagtron T3 Battery Replacement: passo 2, imagem 3 %32
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      Pergunte ao FixBot
      Comentar
    1. Swagtron T3 Battery Replacement, Battery: passo 3, imagem 1 %32
      • Unscrew the four 9.4 mm Phillips #1 machine screws attaching the battery to the base of the Swagtron T3.
      Pergunte ao FixBot
      Comentar
    2. Swagtron T3 Battery Replacement: passo 4, imagem 1 %32 Swagtron T3 Battery Replacement: passo 4, imagem 2 %32
      • Detach the two cables connecting the battery to the Swagtron by pinching the connector clips and pulling the cables apart:
      • One red and black cable with a yellow connector.
      • One blue cable with a black connector.
      Pergunte ao FixBot
      Comentar
    3. Swagtron T3 Battery Replacement: passo 5, imagem 1 %32 Swagtron T3 Battery Replacement: passo 5, imagem 2 %32
      • Remove the battery by pulling it out from under the cables.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S13-G3, Forte Spring 2017 Membro de Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Membros
Autoria de 4 guias
11Comentários do guia
where can i get a replacement battery?
rob - Responder Compartilhar
Where can I get a replacement battery?
I can’t find a battery with the two wire harnesses coming out of the pack. Where can I order one?
Jeff Johnson - Responder Compartilhar
Where Can I purchase a replacement batter for the T3
Leandre - June 18
Leandre Thornton - Responder Compartilhar
Swagtron doesn’t sell the silver battery (even if you email them) I bought one from HoverboardRepair.com and it worked. Only difference is the small wire doesn’t come on the new battery but my hoverboard has worked just fine and I replaced the battery months ago.
Daniel Moravec - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 66
Ao todo: 8,960
