Ir para o conteúdo principal
SwagTron T1 Gyroscope Replacement
O que você precisa
    1. SwagTron T1 Gyroscope Replacement, Back Panels: passo 1, imagem 1 %32
      • Ensure that the SwagTron is off.
      • Turn the SwagTron upside down to see the underside.
      Pergunte ao FixBot
      Comentar
    2. SwagTron T1 Gyroscope Replacement: passo 2, imagem 1 %32 SwagTron T1 Gyroscope Replacement: passo 2, imagem 2 %32 SwagTron T1 Gyroscope Replacement: passo 2, imagem 3 %32
      • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
      • The screws are tightly in place. It will take effort to screw them out.
      • The panel is still attached to the SwagTron by wires that go to the motherboard.
      • Carefully lift the panels off
      Pergunte ao FixBot
      Comentar
    3. SwagTron T1 Gyroscope Replacement: passo 3, imagem 1 %32 SwagTron T1 Gyroscope Replacement: passo 3, imagem 2 %32 SwagTron T1 Gyroscope Replacement: passo 3, imagem 3 %32
      • Follow the wires from the panels to the motherboard.
      • You may need to cut any zip ties that are holding the wires together.
      • There is one connection on the battery side and three on the other side that must be removed.
      • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
      • Your back panels are now completely removed.
      Pergunte ao FixBot
      Comentar
    1. SwagTron T1 Gyroscope Replacement, Gyroscope: passo 4, imagem 1 %32 SwagTron T1 Gyroscope Replacement, Gyroscope: passo 4, imagem 2 %32
      • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
      Pergunte ao FixBot
      Comentar
    2. SwagTron T1 Gyroscope Replacement: passo 5, imagem 1 %32
      • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
      Pergunte ao FixBot
      Comentar
    3. SwagTron T1 Gyroscope Replacement: passo 6, imagem 1 %32 SwagTron T1 Gyroscope Replacement: passo 6, imagem 2 %32 SwagTron T1 Gyroscope Replacement: passo 6, imagem 3 %32
      • Carefully remove the gyroscope component from the SwagTron.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Teagan Allen
Membro desde: 04/18/17
432 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G5, Banghart Spring 2017 Membro de Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Membros
Autoria de 15 guias
5Comentários do guia
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - Responder Compartilhar
Amazon.com Keyword: CertiCable
Jesse Griffis - Responder Compartilhar
Where do you get the replacement?
Brittany Conner - Responder Compartilhar
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - Responder Compartilhar
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 63
Ao todo: 8,385
