Ir para o conteúdo principal
SwagTron T1 Battery Replacement
O que você precisa
  1. SwagTron T1 Battery Replacement, Back Panels: passo 1, imagem 1 %32
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
    Pergunte ao FixBot
    Comentar
  2. SwagTron T1 Battery Replacement: passo 2, imagem 1 %32 SwagTron T1 Battery Replacement: passo 2, imagem 2 %32 SwagTron T1 Battery Replacement: passo 2, imagem 3 %32
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
    Pergunte ao FixBot
    Comentar
  3. SwagTron T1 Battery Replacement: passo 3, imagem 1 %32 SwagTron T1 Battery Replacement: passo 3, imagem 2 %32 SwagTron T1 Battery Replacement: passo 3, imagem 3 %32
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
    Pergunte ao FixBot
    Comentar
  4. SwagTron T1 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Your SwagTron should look like this once the back panels are removed.
    • The battery is located on the left side as shown.
    Pergunte ao FixBot
    Comentar
  5. SwagTron T1 Battery Replacement: passo 5, imagem 1 %32 SwagTron T1 Battery Replacement: passo 5, imagem 2 %32
    • Unscrew the four 10mm screws that secure the battery using a Philips #2 screwdriver.
    • The screws may be tightly in place. If so, use some effort to unscrew them.
    • The battery is still connected to two wires that go to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. SwagTron T1 Battery Replacement: passo 6, imagem 1 %32 SwagTron T1 Battery Replacement: passo 6, imagem 2 %32 SwagTron T1 Battery Replacement: passo 6, imagem 3 %32
    • Disconnect the two wires that come from the battery from the wires coming from the hoverboard.
    • There are only two connections that need to be separated.
    • The battery should be completely removed from the hoverboard.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Adrian Abarca
Membro desde: 04/18/17
363 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G5, Banghart Spring 2017 Membro de Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Membros
Autoria de 5 guias
16Comentários do guia
Is there a blue and black wire that gets connected also?
Where dI you get the battery.
Thanks.
Paul Bromberg - Responder Compartilhar
I’m also wanting to know where you found the replacement battery. I’ve found several replacement battery packs for hover boards but none that match the T1. The T1 has a circuit board attached to the battery pack, fused…. where can I find this?
Daniel O'Brien - Responder Compartilhar
Yep, can’t find a T1 battery anywhere. Even Swagtron won’t tell me how to get one, short of sending it in for service.
renystro - Responder Compartilhar
Swagtron tech support offers to replace any battery if under warranty, which requires that you pay to ship the entire unit back to them for service. This seems insanely costly, but probably avoids voiding the warranty.
If you are out-of-warranty, they said they would sell me a battery, but did not offer any pricing info.
If you want to do-it-yourself, out-of-warranty: My guess it that the metal shielded “battery” actually contains commercially available LiIon cells which can be privately sourced, but may require some wire splicing, may be a shock hazard and such, so is more complex than just plug-in a replacement.
Chris Gray - Responder Compartilhar
What type of replacement battery is used for the Swagtron T1?
Swagtron wont give me the information!!
Maria Taylor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 77
Ao todo: 15,648
