Ir para o conteúdo principal
Super Nintendo Controller Port Replacement
O que você precisa
  1. Super Nintendo Controller Port Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Super Nintendo Controller Port Replacement: passo 2, imagem 1 %32 Super Nintendo Controller Port Replacement: passo 2, imagem 2 %32 Super Nintendo Controller Port Replacement: passo 2, imagem 3 %32
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    Pergunte ao FixBot
    Comentar
  3. Super Nintendo Controller Port Replacement, Eject Button: passo 3, imagem 1 %32 Super Nintendo Controller Port Replacement, Eject Button: passo 3, imagem 2 %32
    • Lift the right side of the eject lever out of the housing.
    Pergunte ao FixBot
    Comentar
  4. Super Nintendo Controller Port Replacement: passo 4, imagem 1 %32 Super Nintendo Controller Port Replacement: passo 4, imagem 2 %32 Super Nintendo Controller Port Replacement: passo 4, imagem 3 %32
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
    Pergunte ao FixBot
    Comentar
  5. Super Nintendo Controller Port Replacement, Controller Port: passo 5, imagem 1 %32
    • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
    Pergunte ao FixBot
    Comentar
  6. Super Nintendo Controller Port Replacement: passo 6, imagem 1 %32 Super Nintendo Controller Port Replacement: passo 6, imagem 2 %32
    • Carefully remove the ribbon cable from its port.
    Pergunte ao FixBot
    Comentar
Conclusão
18 outras pessoas executaram este guia.
James Shirley
Membro desde: 10/03/10
1.033 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-47, Amido Fall 2010 Membro de Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Membros
Autoria de 25 guias
3Comentários do guia
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - Responder Compartilhar
This isn’t complete. How about taking the face plate off?
Daniel Powers - Responder Compartilhar
Find don’t look like screws they look like rivets
Steve Pitcher - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 38
Últimos 30 dias: 211
Ao todo: 37,231
