Ir para o conteúdo principal
Substituição do disco rígido do iMac 27" 2017
O que você precisa
  1. Substituição do disco rígido do iMac 27" 2017, Instalar o suporte de reparos: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    iMac Intel 27" Cardboard Service Wedge
    What’s the point of this? You run the wheel around the outside, and then you lay it down anyway to pull the glass and do the rest. The wedge is not needed.
    ebay - Responder
    I have a story to tell about this teardown. It all went wonderfully well until after I completed the process and attempted to format my new SSD drive only to discovery that the capacity of the drive was 256GB… not the 2TB I was sure I had ordered. iFixit was very supportive and helpful in sending me a new set of sticky tape strips and and RMA to return the SSD and some of the other parts.
    I finally had received my new set of strips and the 2TB SSD…. I figured, piece of cake… I already know how to do this… but I watched the video again and started following the teardown…
    …apparently the new sticky tape strips was way more powerful that the original tape and while using the pizza cutter tool and not advancing much, I proceeded to use one of the iFixit credit card style wedges…. I now have 2 pretty severe cracks on the glass of my display, which as clearly explained by @mayer can only be replaced by an entire display… which runs at about $500. Cosmetically it looks horrible, but it works… for now.
    Erich Hentschel - Responder
  2. Substituição do disco rígido do iMac 27" 2017, Introduzir uma ferramenta de abertura: passo 2, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Introduzir uma ferramenta de abertura: passo 2, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017, Introduzir uma ferramenta de abertura: passo 2, imagem 3 %32
    • Começando pelo lado esquerdo da tela, próximo ao botão de liga/desliga, introduza a ferramenta de abertura para iMac no vão entre o painel de vidro e a estrutura traseira.
    • O eixo da ferramenta de abertura para iMac evita que você introduza muito para dentro a roda. Se estiver usando uma ferramenta diferente, não a introduza mais do que 9,5 mm dentro da tela. Você corre o risco de romper os cabos da antena e causar sérios danos se introduzir demais a ferramenta.
    Should you run a hair dryer along the edges first?
    Al Val - Responder
  3. Substituição do disco rígido do iMac 27" 2017, Cortar o adesivo da tela: passo 3, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Cortar o adesivo da tela: passo 3, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017, Cortar o adesivo da tela: passo 3, imagem 3 %32
    • Use a ferramenta como um cortador de pizza - empurre-a por toda a extensão do vão e ela cortará o ponto central do adesivo de espuma.
    • Lembre-se de empurrar constantemente o punho atrás da roda cortante. Se você puxar, a roda pode escapar do punho.
    • Passe a ferramenta por toda a extensão da lateral esquerda da tela.
  4. Substituição do disco rígido do iMac 27" 2017, Cortar o adesivo restante: passo 4, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Cortar o adesivo restante: passo 4, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017, Cortar o adesivo restante: passo 4, imagem 3 %32
    • Continue rolando a ferramenta para cima, virando no canto esquerdo superior.
  5. Substituição do disco rígido do iMac 27" 2017: passo 5, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 5, imagem 2 %32
    • Corte o adesivo da parte esquerda superior da tela.
  6. Substituição do disco rígido do iMac 27" 2017: passo 6, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 6, imagem 2 %32
    • Continue na parte superior da tela.
    • Você precisa passar a ferramenta algumas vezes para trás e para a frente onde já cortou adesivo, para garantir que tenha soltado o máximo possível de adesivo.
  7. Substituição do disco rígido do iMac 27" 2017: passo 7, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 7, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 7, imagem 3 %32
    • Passe a ferramenta pelo canto superior direito da tela.
  8. Substituição do disco rígido do iMac 27" 2017: passo 8, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 8, imagem 2 %32
    • Role a ferramenta para baixo, por toda a extensão da lateral direita da tela.
  9. Substituição do disco rígido do iMac 27" 2017: passo 9, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 9, imagem 2 %32
    • Finalize empurrando a ferramenta de abertura para a parte inferior na lateral direita da tela.
    • A esta altura, você pode passar a ferramenta por toda a tela, voltando no sentido inverso, para garantir que tenha cortado o máximo possível de adesivo.
  10. Substituição do disco rígido do iMac 27" 2017, Separar a tela: passo 10, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Separar a tela: passo 10, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017, Separar a tela: passo 10, imagem 3 %32
    Plastic Cards
    $2.99
    • Ainda que a ferramenta de abertura já tenha feito a parte difícil do trabalho, a tela ainda estará levemente colada na estrutura. Será necessário usar um cartão de plástico para soltar o resto desse adesivo.
    • Coloque o iMac numa mesa com a tela virada para cima.
    • Começando pelo canto direito superior do iMac, introduza um cartão de plástico por entre a tela e a moldura.
    • Tenha cuidado para não introduzi-la mais do que 9,5 mm, caso contrário você danificará componentes internos.
  11. Substituição do disco rígido do iMac 27" 2017: passo 11, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 11, imagem 2 %32
    • Vire o cartão de plástico cuidadosamente para abrir o espaço entre a tela e a moldura, e corte os adesivos resistentes próximos ao canto.
    • Se você usar muita força, irá quebrar o vidro. Trabalhe com cuidado e tente formar um vão que não seja maior do que 6 mm.
  12. Substituição do disco rígido do iMac 27" 2017: passo 12, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 12, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 12, imagem 3 %32
    • Pare de cortar antes da câmera iSight neste passo, caso contrário você pode danificá-la.
    • Passe o cartão na direção do centro da tela para cortar os adesivos resistentes.
  13. Substituição do disco rígido do iMac 27" 2017: passo 13, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 13, imagem 2 %32
    • Introduza o cartão novamente no canto e deixe-o nessa posição para evitar que o adesivo cole novamente.
  14. Substituição do disco rígido do iMac 27" 2017: passo 14, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 14, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 14, imagem 3 %32
    • Introduza um segundo cartão no vão, por entre a tela e a moldura, no canto esquerdo superior.
  15. Substituição do disco rígido do iMac 27" 2017: passo 15, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 15, imagem 2 %32
    • Vire gentilmente o cartão, aumentando ligeiramente o espaço entre a tela e a moldura.
    • Como na outra lateral, mova lentamente para permitir que o adesivo se rompa e tenha cuidado para não tensionar demais o vidro da tela.
  16. Substituição do disco rígido do iMac 27" 2017: passo 16, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 16, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 16, imagem 3 %32
    • Passe o cartão de plástico na direção do centro, parando novamente um pouco antes da câmera iSight.
  17. Substituição do disco rígido do iMac 27" 2017: passo 17, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 17, imagem 2 %32
    • Introduza o cartão de volta no canto esquerdo superior.
  18. Substituição do disco rígido do iMac 27" 2017: passo 18, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 18, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 18, imagem 3 %32
    • Com os cartões introduzidos próximo aos cantos, como mostra a figura, vire cuidadosamente os cartões para aumentar o vão entre a tela e a estrutura.
    • Se em algumas partes o adesivo ainda estiver colando e não puder ser separado, pare de fazer movimentos de vai-e-vem e use um dos cartões para cortar o adesivo nesta área.
    • Comece a erguer a parte superior da tela para fora da moldura.
    • Erga a tela somente umas poucas polegadas - ela ainda está presa ao iMac pelos cabos de dados e de energia.
  19. Substituição do disco rígido do iMac 27" 2017, Desconectar os cabos da tela: passo 19, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Desconectar os cabos da tela: passo 19, imagem 2 %32
    • Enquanto segura a tela com uma mão, use a outra para desconectar o cabo de energia da tela.
    • Erga a tela o suficiente para facilitar o acesso às conexões, mas não tanto que os cabos fiquem estendidos e as suas conexões sejam danificadas (umas 8'').
    Der Stecker muss seitlich wie die meisten anderen Stecker in diesem Modell komprimiert werden, um ihn aus der Buchse auf dem Logicboard zu ziehen. Die Zugrichtung ist parallel zum Logicboard in Richtung Oberkante des iMac. Ziehen ohne seitliches Zusammendrücken der Backen am Stecker könnte den Stecker oder die Buchse beschädigen.
    Ernest Bumblebee - Responder
    These instructions are unclear. They imply the cable can just be pulled out but this step had me stuck for a bit. Searching the webs, I discovered that there are little tabs on either side of the connector. I used my prod tool and poked one side and the connector came out a little. I poked the other side the connector came out without a fight.
    Peter Akey - Responder
    The instruction for this step state this but I was still not expecting two cables. Finally figured out there is a Display Power and a separate Display Data cable.
    wsrb - Responder
    As others have mentioned later on, it is not necessary to fully remove the screen or disconnect these cables. I managed with just the screen held wedged open with a small cardboard box.
    Jamie Bamborough - Responder
  20. Substituição do disco rígido do iMac 27" 2017: passo 20, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 20, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 20, imagem 3 %32
    • Vire para cima o suporte metálico com trava do cabo de dados da tela.
    • Desconecte o cabo de dados da tela.
    • Esta conexão é sensível e pode se romper facilmente. Certifique-se de puxar em linha reta o conector do cabo de dados da tela para fora do soquete, em direção à parte superior do iMac.
  21. Substituição do disco rígido do iMac 27" 2017, Elevar a tela: passo 21, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Elevar a tela: passo 21, imagem 2 %32
    • Erga a tela até ela quase alcançar uma posição vertical.
    • A esta altura, ainda há uma tira de adesivo na extensão da parte inferior da tela, que segurará a tela à moldura, fazendo as vezes de uma dobradiça. Você pode soltar este adesivo erguendo e baixando a tela por algumas vezes.
    After rocking the display back and forth a bit, I found it helpful to use my iMac opening tool to gently slide ever so slightly underneath the bottom of the glass to cut the adhesive. This was with the display lowered back into it its normal position. I just worked about 1 millimetre deep at a time and eventually cut through the ~8” adhesive strip at the bottom centre.
    Henry Rose - Responder
    It's possible to skip this step and go to step 24, leaving the display attached. You'll want to open the display just enough to replace the drive, with the machine upright and supported so the display doesn't swivel (I fold up a small pillow and wedge it in there). This way you don't have to worry about damaging the display when removing it, or aligning it when replacing it (which can be difficult to do solo as it's big and heavy).
    Using a T8 with a short handle is helpful here, and make sure it's well magnetized so you don't drop the screws for the hard drive (just leave the other ones in the speakers).
    maccentric - Responder
  22. Substituição do disco rígido do iMac 27" 2017, Remover o adesivo restante: passo 22, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Remover o adesivo restante: passo 22, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017, Remover o adesivo restante: passo 22, imagem 3 %32
    • Tenha muito cuidado para não tocar nos terminais do condensador ou nas juntas de solda expostas na parte traseira da fonte de alimentação (no quadrado vermelho).
    • Agarre a pequena tira na extremidade de uma das fitas adesivas da tela na borda inferior e puxe o adesivo na direção da parte superior do iMac para removê-lo.
    • Repita esse passo com a outra faixa adesiva e remova-a.
    • Se uma das tiras adesivas se romper antes de ser removida, use um cartão plástico para cortar o adesivo restante.
  23. Substituição do disco rígido do iMac 27" 2017, Remover a tela: passo 23, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Remover a tela: passo 23, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017, Remover a tela: passo 23, imagem 3 %32
    • Tenha muito cuidado ao manusear a tela, ela é grande, pesada e feita de vidro. A tela tem bordas frágeis. Evite erguer a tela pelos cantos.
    • Erga a tela da moldura e remova-a do iMac. Deite a tela virada para baixo numa superfície plana e macia.
    • Pode ser que seja necessário erguê-la lentamente de um lado, para soltar o adesivo restante.
    • Depois de cortado o adesivo, ele não pode mais ser usado para vedar a tela. Vá para este guia quando o seu reparo tiver sido completado para repor as tiras de adesivo que seguram a tela no seu invólucro traseiro.
  24. Substituição do disco rígido do iMac 27" 2017, Remoção do alto-falante Intel do iMac para guias do HD: passo 24, imagem 1 %32
    • Com uma chave T10, remova os dois parafusos de 10 mm que fixam o alto-falante esquerdo.
  25. Substituição do disco rígido do iMac 27" 2017: passo 25, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 25, imagem 2 %32
    • Afaste o alto-falante solto para a esquerda - o bastante para expor os parafusos do suporte do disco rígido.
  26. Substituição do disco rígido do iMac 27" 2017: passo 26, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 26, imagem 2 %32
    • Puxe para cima em linha reta o cabo SATA combinado para desconectá-lo da unidade HD.
    Where can I purchase this cable if my iMac only came with the m.2 SSD?
    Julien Dal Col - Responder
  27. Substituição do disco rígido do iMac 27" 2017: passo 27, imagem 1 %32
    • Com uma chave T8, remova os dois parafusos de 7,3 mm que fixam o suporte esquerdo do disco rígido na estrutura traseira.
    they are T9 for 2012.
    sean_gizzle - Responder
  28. Substituição do disco rígido do iMac 27" 2017: passo 28, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 28, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 28, imagem 3 %32
    • Agarre ambos, o disco rígido e o suporte esquerdo do disco rígido.
    • Levante a lateral esquerda, afastando-a da estrutura traseira, e puxe a unidade para a esquerda.
    • Remova o disco rígido e o suporte esquerdo do disco rígido do iMac.
  29. Substituição do disco rígido do iMac 27" 2017: passo 29, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 29, imagem 2 %32
    • Remova o suporte esquerdo do disco rígido.
  30. Substituição do disco rígido do iMac 27" 2017, Disco rígido: passo 30, imagem 1 %32
    • Remova os quatro pinos-parafusos T8 de 8,1 mm do disco rígido e transfira-os para o invólucro da unidade nova.
    In my case these were T9 screw posts. Late 2012 iMac. They had traces of Loctite on them.
    rsnadd - Responder
  31. Substituição do disco rígido do iMac 27" 2017, Trocar o disco rígido com um kit SSD: passo 31, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017, Trocar o disco rígido com um kit SSD: passo 31, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017, Trocar o disco rígido com um kit SSD: passo 31, imagem 3 %32
    • Siga os passos restantes se estiver substituindo o seu disco rígido por um kit SSD.
    • Se o seu invólucro de SSD for como o da primeira imagem, vá em vez disso para este guia.
    • Alinhe os conectores do SSD com os soquetes do invólucro metálico.
    • Pressione a unidade contra os soquetes do invólucro, até que o SSD se assente firmemente.
    • O SSD se conecta com o invólucro somente numa única direção. Se não conseguir alinhar os conectores, vire o SSD e tente novamente.
    what if I’m installing a hard drive?
    Troy Garcia - Responder
    Didn’t bother with the SSD caddy. Some 3M sticky pads did the trick!
    James Clive - Responder
    Been using them for years...works great.
    Michael Maxson -
    Two thoughts on SSD replacement/upgrade:
    1) It would help if some references were made to help us determine what we need in terms form factors. I’ve never used an SSD and see a 2.5” one that would work, but I don’t know if 2.5” SSDs are different (in form factor) from 2.5” HDs. A lot of us are still learning about SSDs and isn’t that what this site is about? (Learning new things about hardware and using hardware?)
    2) I’m not clear if I definitely need a new temperature sensor if I put in an SSD or if
    Hal Vaughan - Responder
    Can I buy the kit without the SSD. I'm thinking of replacing my 3TB hard drive with a 4TB SSD.
    Also, would you happen to know what the maximum hard drive dimension that can fit inside of this iMac? I may try a 14TB hard drive instead.
    Larry - Responder
    A 14Tb HDD does not represent any problem. But I will care about rising temperature. Must attach a heat sensor. If rise to high, it will suddenly shutdown to protect it.
    Neos Marketing -
    Is it possible to have some reference of compatible SSD please?
    I would like to replace the HDD from my Fusion drive, Imac 5K late 2014, by a SSD.
    But i don't know which model should i take, and there is no recommandation on this website :(
    thanks in advance
    Nathan André - Responder
    Is it possible to use an M.2 NVMe SSD with an adapter (mount) for a 2.5" SATA SSD instead of a SATA SSD?
    Kirill Legion - Responder
    Great tuning set and tutorial.
    With the new SSD my late 2012 iMac feels like 10 years younger now! :-)
    The only things to mention:
    - before starting read the whole tutorial very carefully!
    - prepare your working place
    - take enough time for each step!!
    Chris Wagner - Responder
  32. Substituição do disco rígido do iMac 27" 2017: passo 32, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 32, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 32, imagem 3 %32
    • Com uma chave Phillips, instale os quatro parafusos prateados (dois de cada lado) ao longo das bordas do SSD para fixá-lo no invólucro.
  33. Substituição do disco rígido do iMac 27" 2017: passo 33, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 33, imagem 2 %32
    • Conecte o cabo combinado habilitado a sensores à porta do invólucro.
    • O cabo somente pode ser conectado em uma única orientação. Se não conseguir conectar o cabo, gire-o 180º e tente novamente.
    Is the thermal sensor needed? I fitted a replacement SSD and it’s all back together and the iMac’s fans are fine. They don’t go into full max speed mode.
    If you have a problem with the fans, you can always use Macs Fan Control (free) to set the speed. The sensor is not needed.
    maccentric -
    Hi, thanks for good information. Do we need intermediate SSD cables (red, black and yellow)? iMac has SATA original cable.
    O S - Responder
  34. Substituição do disco rígido do iMac 27" 2017: passo 34, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 34, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 34, imagem 3 %32
    • Remova a película branca da traseira da pequena placa de sensor de temperatura para expor o adesivo.
    • Cole a placa do sensor de temperatura numa superfície metálica exposta do SSD, próximo ao conector SATA.
    • Dobre o excesso dos fios do sensor de temperatura, de forma que eles não atrapalhem enquanto você instala o invólucro.
    Great pics ! Is that “temp sensor board” is already on my HDD IMAC ?? Or must I buy one ?
    kenclark200 - Responder
    Don’t bother with the thermal sensor. I didn’t fit one and the iMac is working fine and no fans are kicking in.
    Instructions say to attach sensor to the SSD, but all pictures show it being attached to the SSD carrier. This may not represent accurate SSD temp as much of the carrier dissipates the heat absorbed from the SSD
    chris byrne - Responder
    Confirmed, no need for the extra temp sensor on Mid-2015 iMac. (EMC 2806, Mid-2015 27" iMac). Just changed the old 1TB HDD to SSD, no extra fan RPM after power on.
    Laszlo Nyirfa - Responder
    The adhesive on the sensor is very weak. My sensor fell off after a couple of days. Is there a safe glue to use to adhere it to the SSD? Super glue?
    estyle18 - Responder
    FWIW I bought a 4TB Western Digital Blue SSD. The entire case of the SSD is plastic- there is no metal. Hoping the temp sensor adheres to it okay.
    Kupe - Responder
    de donde salio el sensor de temperatura? lo trae el disco nuevo?
    Pedro - Responder
  35. Substituição do disco rígido do iMac 27" 2017: passo 35, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 35, imagem 2 %32
    • Com uma chave T8, instale os pinos de montagem do disco rígido velho nas laterais do invólucro.
  36. Substituição do disco rígido do iMac 27" 2017: passo 36, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 36, imagem 2 %32
    • Fixe os suportes de montagem removidos do disco rígido velho no invólucro.
    i don't have a combo cable.i also didn't have asata drive. just a blade ssd. i don't see wwhere i could add a cable
    Larry Paterson - Responder
  37. Substituição do disco rígido do iMac 27" 2017: passo 37, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 37, imagem 2 %32
    • Conecte o cabo combinado do iMac ao novo cabo combinado habilitado para temperatura.
  38. Substituição do disco rígido do iMac 27" 2017: passo 38, imagem 1 %32 Substituição do disco rígido do iMac 27" 2017: passo 38, imagem 2 %32 Substituição do disco rígido do iMac 27" 2017: passo 38, imagem 3 %32
    • As imagens usadas neste passo são de um iMac de 2017. Os seus cabos podem ser diferentes, mas o procedimento é o mesmo.
    • Empurre o invólucro do SSD no espaço ocupado anteriormente pelo disco rígido.
    • Disponha os cabos de tal forma que eles não interfiram nenhum outro componente.
    • Tente manter os cabos afastados de dobras acentuadas e passe-os de tal forma que eles não sejam apertados.
    The SATA cable on my Late 2012 was not long enough to comfortably attach to the end of the temperature sensor array after it was plugged into the new SSD. I had to fold the array and slide it under the SSD and housing. There was much resistance to the folding so I took it slowly to let the wires adjust gradually to the fold so they would not break.
    Bob Enders - Responder
    Unfortunately, the adapter that comes with it isn't long enough to avoid pushing against the screen in the front. One week after upgrading to SSD my screen fell off shattering and breaking the power connector on the systems board. A new screen is ordered but I'm hoping the power connector isn't damaged beyond repair. I'm going to try to adhere the HD adapter to the back inside of the case with 3m adhesive to avoid pressure against the screen.
    Erik Johnson - Responder
    As a newbie, the only other upgrade I have done is to replace my iPhone 7 battery. I had trouble on reassembly.
    This is a great upgrade guide, but it would be important to me to see the reassembly instructions including the cautions.
    For example, I had issues with reattaching the plugs in the phone. I could see having an issue with them here, as well as repositioning the display back into the cabinet.
    I do PCB board repair work and repair pinball machines. But I won’t try this.
    LexVAPin - Responder
    how do i glue on the new screen? which glue is used?
    Marc Seeh - Responder
    Try 3m double sided tape from Amazon, it available in 3mm width which is ideal for iMac screen. It has a very thin foam and is much better quality than the cheap Chinese kits available on Amazon. You will have to trim it to size with a sharp craft blade as you fit. Don’t risk your screen falling off from using cheap tape in the so called fitting kits!
    Tony Street - Responder
    In my Late 2012 27" iMac I Scotch-taped the SATA connector to the case to stop it from pushing against the screen after reassembly.
    Richard Brockbank - Responder
    Only 39 steps!
    Is it possible to clone the internal disk and have the imac boot off the external SSD?
    D Leinweber - Responder
    The extension cable is too long. I folded it over carefully & stuck it down to the case using a double sided sticky pad. Photo here
    https://www.icloud.com/sharedalbum/#B0qG...
    Bill4321 - Responder
    hi is it possible to use another caddy caddy 3,5" ---> 2,5" for the upgrade? I think the logic board of the one that comes in the kit is faulty.
    Thanks
    Radament - Responder
    There is no need for a temperature sensor on a Late-2013 and later.
    Phil Taylor - Responder
Conclusão
Compare a sua nova peça de reposição com a peça original - pode ser que você precise transferir componentes remanescentes ou remover suportes adesivos da nova peça antes de instalá-la.
Para a remontagem do seu dispositivo, siga essas instruções na ordem inversa.
Leve o seu lixo eletrônico para um ponto de recolha ou uma recicladora certificada.
O reparo não estão indo conforme o planejado? Confira a nossa comunidade do fórum Respostas para obter ajuda na solução de problemas.
53 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
en pt
100%
Udo Baingo está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Adam O'Camb
Membro desde: 04/11/15
209.006 Reputação
Autoria de 416 guias
12 comentários
Hello, I have an iMac (Retina 5K, 27-inch, 2017) and I would like to change my hard disk, which is a 3.5GHz 1TB Fusion Unit, for an SSD disk, would you recommend doing it? And if so, what reference or brand do you recommend to do it?
Julio Cesar Ortiz Soto - Responder
I can confirm the OWC thermal sensor cable is not needed for HDD to SSD upgrade. I successfully upgraded my 2017 5k iMac fusion drive’s HDD to WD blue 2TB SATA3 ssd without it and the fans speeds don’t ramp up at all. Anyhow thanks for your guides Ifixit on how to DIY. I successfully upgraded my 128gb NVME to a 1TB NVME and to a SATA3 ssd for storage. Transfer speeds are insane and my boot up time now only takes 12 seconds compared to 32 seconds previously. I also upgraded my cpu from the i5-7600k to the i7-7700k. My 2017 5k iMac is blazing fast now. Thanks again ifixit.
Andy C - Responder
Successfully upgraded to a 2TB SSD from the 2TB Fusion drive. As soon as I turned on Bootcamp, the Fusion drive went nuts for a few weeks I think because it prioritized the Windows side onto the SSD and the Mac side onto the spinning drive. It eventually corrected itself but it was a helluva time. And it was time for a fresh hard drive anyway. $500 is much cheaper than a new iMac. Highly recommend this one. This was way easier than my upgrades to the 2009 and to a Mac Mini.
Michael Higdon - Responder
Excellent instructions. The process is straightforward - the only tricky bit is reinstalling the screen accurately. There seems to be some conflicting views on the internet about the best way to do it and which adhesive strips to use - the 2012-2015 strips now seem to be supplied for later models, and they worked fine on my 2017 iMac.
My advice is just to take take it all very steadily and always read one stage ahead before you start on your next stage just to know where you are going next. I installed a 2TB Crucial SSD and the results are very good.
Roland Denning - Responder
i not understand how the temperature sensor work. its connected with three wires on power connector (two negative one positive 5v) i think this powering the sensor. but i not understand how its comunicate with the mainboard the temperature releved.
calecad - Responder
ive been looking for info on the blade drive as wiping a newly installed SSD and installing OS works, but what is best practice for this? what do we use the blade for after, is it just wiped and left redundant? - as for the temp control, just install Macs Fan Control.
Pete Gypps - Responder
i did this but then my imac showed a folder with a question mark on it
Nehemiah Whipple - Responder
Great guide! Amazing work here.
Gabe Price - Responder
Noch nie zuvor hatte ich so eine professionelle Anleitung gelesen.
EINFACH SUPER
Horst Söllner - Responder
If adding a 2nd ssd (I am just learning that this ssd upgrade kit won’t actually replace my preinstalled ssd), how do I plug in the new ssd? There’s no sata cabled exposed.
Nino Mancuso - Responder
Regarding some previous comments, this guide is for replacing a drive if the original has died or is to be upgraded. You will have to reinstall MacOS or transfer your data to the new drive. This won't help you install a second additional drive, and a brand new drive will not work on its own.
Greg Phillips - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 87
Últimos 7 dias: 589
Últimos 30 dias: 2,547
Duração total: 103,202
