Ir para o conteúdo principal
Stuck Shutter Fix Replacement
    1. Stuck Shutter Fix Replacement, Shutter: passo 1, imagem 1 %32
      • Put the camera in any mode other than Auto, and turn off the flash.
      • Turn off the LCD screen and press the DISP or DISPLAY button.
      Pergunte ao FixBot
      Comentar
    2. Stuck Shutter Fix Replacement, Adjust the Camera Setting: passo 2, imagem 1 %32
      • For many canon cameras this will be shutter priority mode, that will give you the longest exposure time without flash.
      Pergunte ao FixBot
      Comentar
    3. Stuck Shutter Fix Replacement, Open/Close the Battery Door: passo 3, imagem 1 %32
      • After a few seconds open the battery door then close it again. This will momentarily interrupt power during the exposure time.
      • Repeat the procedure until the shutter becomes unstuck.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 59
Últimos 30 dias: 207
Ao todo: 10,104
