Ir para o conteúdo principal
Sticky Key Saxophone Fix
O que você precisa
  1. Sticky Key Saxophone Fix, Sticky Key Saxophone Fix: passo 1, imagem 1 %32
    • Locate sticking key.
    If it's sticky because of the pad not wanting to let go (as opposed to screw too tight, limiting movement) then just take a dollar bill (or a 20 if ur rich) and place it between the pad and the hole while pressing on the pad with your finger to hold it closed as you pull out the bill over and over helps absorb the moisture so it stops sticking.
    Jordan Glad - Responder
  2. Sticky Key Saxophone Fix: passo 2, imagem 1 %32
    • Screws are located down from key.
  3. Sticky Key Saxophone Fix: passo 3, imagem 1 %32
    • Loosen screw slowly and carefully, so that screw isn't lost.
  4. Sticky Key Saxophone Fix: passo 4, imagem 1 %32
    • Test key and note free movement.
  5. Sticky Key Saxophone Fix: passo 5, imagem 1 %32
    • Put saxophone completely together and test out key.
    • If key still sticks repeat previous steps.
Conclusão
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
AlysonStrange
Membro desde: 05/30/17
101 Reputação
Autoria de 1 guia
Um comentário
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 1,910
