Ir para o conteúdo principal
Sticky Key Saxophone Fix
O que você precisa
    1. Sticky Key Saxophone Fix, Sticky Key Saxophone Fix: passo 1, imagem 1 %32
      • Locate sticking key.
      Pergunte ao FixBot
      Comentar
    2. Sticky Key Saxophone Fix: passo 2, imagem 1 %32
      • Screws are located down from key.
      Pergunte ao FixBot
      Comentar
    3. Sticky Key Saxophone Fix: passo 3, imagem 1 %32
      • Loosen screw slowly and carefully, so that screw isn't lost.
      Pergunte ao FixBot
      Comentar
    4. Sticky Key Saxophone Fix: passo 4, imagem 1 %32
      • Test key and note free movement.
      Pergunte ao FixBot
      Comentar
    5. Sticky Key Saxophone Fix: passo 5, imagem 1 %32
      • Put saxophone completely together and test out key.
      • If key still sticks repeat previous steps.
      Pergunte ao FixBot
      Comentar
Conclusão
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
AlysonStrange
Membro desde: 05/30/17
101 Reputação
Autoria de 1 guia
1Comentário do guia
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 52
Ao todo: 2,543
