Ir para o conteúdo principal
Step Guide To Install KDZ Firmware Using LG Flash Tool
    • Download the LG flash tool from lgflash.com and extract it on your Windows PC and launch the application
    Pergunte ao FixBot
    Comentar
    • Boot your mobile device into download mode by power of the device and holding the Volume Up button.
    Pergunte ao FixBot
    Comentar
    • Connet it to the pc using a proper USB cable.
    Pergunte ao FixBot
    Comentar
    • Then it is the time for you to load the kdz firmware file into LG Flash Tool window on your PC. Click on the browse button at the end of the 'Select KDZ file' line.
    Pergunte ao FixBot
    Comentar
    • Once you selected the KDZ file Click on CSE Flash button to start the flashing process Remember: The application consists of two different flashing options as CSE and Normal. CSE method wipes away the all the date available on your device But the normal method does not. If you want to upgrade from a stock firmware, selest normal
    Pergunte ao FixBot
    Comentar
    • Hit on the start button to proceed. it may be asked for administrator permissions for some LG program on your PC, if just accept it. Select the appropriate language.
    Pergunte ao FixBot
    Comentar
    • Keep in mind not to tick the Smartphone upgrade checkbox, it’s for Windows Mobile phones, not your LG device running on Android. Finally, You can start the flashing process. Wait Until it does 100%.
    Pergunte ao FixBot
    Comentar
Conclusão
15 outras pessoas executaram este guia.
1Comentário do guia
Got a step by step to downgrade to 10 from 13 on the LG v60 thinq 5g? Phone is from ATT
Keith Kilpatrick - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 58
Últimos 30 dias: 332
Ao todo: 31,125
