Introdução
If you need to replace your GameDAC secondary control button, there are a couple of wire connections one needs to be careful for when opening the GameDAC. Follow this guide to safely access and replace the button from the circuit board.
O que você precisa
Remove the plastic cover using the iFixit opening tool to pry the cover open.
Insert opening picks to keep the cover open as you work your way around the GameDAC.
Pop the cover off.
3 outras pessoas executaram este guia.
