Ir para o conteúdo principal
SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement
O que você precisa
  1. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: passo 1, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: passo 1, imagem 2 %32 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: passo 1, imagem 3 %32
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 2, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 2, imagem 2 %32
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 3, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 3, imagem 2 %32
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 4, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 4, imagem 2 %32
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 5, imagem 1 %32
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 6, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: passo 6, imagem 2 %32
    • Desolder the seven potentiometer pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on Como soldar e dessoldar contatos.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S18-G1, White Winter 2019 Membro de Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
Membros da 4
Autoria de 21 guias
3 comentários
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
Christian Humann - Responder
I would like to know too. Cause it failed for me as well!!
Antonis Lazarakis - Responder
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
Muso!27 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 83
Duração total: 4,620
