Ir para o conteúdo principal
SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement
O que você precisa
  1. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Ear Cushions: passo 1, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Ear Cushions: passo 1, imagem 2 %32
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Circuit Board: passo 2, imagem 1 %32
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 3, imagem 1 %32
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 4, imagem 1 %32
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 5, imagem 1 %32
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Microphone Cable: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull up on the wires connected to the circuit board using tweezers to remove the circuit board from inside the headset.
  7. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 7, imagem 1 %32
    • Desolder the six wired connections on the circuit board.
    • For help desoldering connections, follow this useful guide on Como soldar e dessoldar contatos.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
  8. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 8, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 8, imagem 2 %32
    • Lift up the wire on the rotating wheel with tweezers to move it out of the way of the screws.
    • Remove the two 5mm screws with a Phillips #0 driver head.
  9. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 9, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 9, imagem 2 %32
    • Pull out the rotating wheel from the headset casing.
    • Remove the microphone from the casing with the rotator wheel.
    • After removing the rotating wheel, lift the wheel up and use your other hand to feed the microphone through the case.
  10. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 10, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: passo 10, imagem 2 %32
    • Pull the microphone wire out of the wheel.
    • Forcefully removing the microphone from the wheel may break the plastic wheel.
    • Pull the wire and wheel apart to remove the entire component.
Conclusão
7 outras pessoas executaram este guia.
Vanessa Beeler
Membro desde: 01/24/19
296 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G1, White Winter 2019 Membro de Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
Membros da 4
Autoria de 21 guias
9 comentários
can Ii do this with my Arctis 5?
Vantura - Responder
Ugh! Why do they all fail at mic design so bad? Something that has been mastered for decades. It blows my mind.
Chris - Responder
Is there any place where i can get this cable? I also need a new mic for the wireless pro but steelseries dont sell parts. Somehow it came off and i lost it.
robinmusch - Responder
&&^& my mic died and i don’t have warranty wtf -_-
taps_so - Responder
The left earpiece on mine has a different screw type than phillips for some reason. I think it’s a kind of hex screw but I have hex heads and none worked. Strange that the left and right earpieces use different screws.
Darren Peterson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 34
Últimos 30 dias: 203
Duração total: 12,460
