Ir para o conteúdo principal
Staples 34462 Electric Pencil Sharpener Cutter Replacement
O que você precisa
    1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cover: passo 1, imagem 1 %32
      • Pull out the shavings tray from the pencil sharpener.
      • Beware of loose pencil shavings falling on your workspace.
      Pergunte ao FixBot
      Comentar
    2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 2, imagem 1 %32
      • Turn the pencil sharpener on its side.
      Pergunte ao FixBot
      Comentar
    3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 3, imagem 1 %32
      • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
      • Using the plastic opening tool, remove the back plastic feet.
      • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
      • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
      Pergunte ao FixBot
      Comentar
    4. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 4, imagem 1 %32
      • Carefully pull apart the bottom panel from the top panel.
      • Be careful not to pull too forcefully as the panels are connected by wires.
      • Beware of pencil shavings falling out onto your workspace.
      Pergunte ao FixBot
      Comentar
    5. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 5, imagem 1 %32
      • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
      Pergunte ao FixBot
      Comentar
    6. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 6, imagem 1 %32
      • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
      Pergunte ao FixBot
      Comentar
    7. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 7, imagem 1 %32
      • Carefully pull the cover from the top panel and set it aside.
      Pergunte ao FixBot
      Comentar
    1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cutter: passo 8, imagem 1 %32
      • Orient the top panel so that the sensor bracket is facing you.
      • Using a Phillips00 screwdriver, remove four 10.42mm screws.
      • Using a Phillips00 screwdriver, remove two 6.96mm screws.
      Pergunte ao FixBot
      Comentar
    2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 9, imagem 1 %32
      • Pull out the outside cover to remove it from the cutter chamber and set them side by side.
      Pergunte ao FixBot
      Comentar
    3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: passo 10, imagem 1 %32
      • Carefully pull the cutter out of the cutter chamber.
      • Beware of pencil shavings and debris.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
4Comentários do guia
Very clear, easy to follow. Nice photos.
uccbill - Responder Compartilhar
where can I get a replacement cutter?
Mel Buchanan - Responder Compartilhar
Did you find replacement blades?
Horace M Hargroves - Responder Compartilhar
Absolutely great directions. However I lost the two 10.3mm screws somewhere along the line - I did not go any further at that point. I will check out replacement cutters and see if I want to pursue or purchase new. I believe this was my work stapler of the 80's.
Leslie H - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 40
Ao todo: 3,418
