Ir para o conteúdo principal
Stapler Spring Replacement
O que você precisa
  1. Stapler Spring Replacement, Spring: passo 1, imagem 1 %32 Stapler Spring Replacement, Spring: passo 1, imagem 2 %32
    • Open the stapler by gripping the handle to access the spring.
    Pergunte ao FixBot
    Comentar
  2. Stapler Spring Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pry open the hook found on the pusher using the tweezers.
    • Hold the handle firmly to prevent the stapler from snapping back.
    Pergunte ao FixBot
    Comentar
  3. Stapler Spring Replacement: passo 3, imagem 1 %32
    • Unhook the end of the spring from the pusher.
    • Pinch the spring firmly between your fingers to keep it from snapping back.
    Pergunte ao FixBot
    Comentar
  4. Stapler Spring Replacement: passo 4, imagem 1 %32 Stapler Spring Replacement: passo 4, imagem 2 %32
    • Unhook the other end of the spring from the inside of the handle.
    • The spring should be unthreaded from the holes on the handle's metal part.
    Pergunte ao FixBot
    Comentar
  5. Stapler Spring Replacement: passo 5, imagem 1 %32 Stapler Spring Replacement: passo 5, imagem 2 %32
    • Press down on the metal part inside the handle with your thumbs until it will not go down anymore.
    Pergunte ao FixBot
    Comentar
  6. Stapler Spring Replacement: passo 6, imagem 1 %32 Stapler Spring Replacement: passo 6, imagem 2 %32
    • Push the hammer, the rectangular piece, up and away from the metal part.
    Pergunte ao FixBot
    Comentar
  7. Stapler Spring Replacement: passo 7, imagem 1 %32
    • Release the metal part inside the handle so it comes away from the hammer.
    • Keep hold of the metal part to keep it from snapping closed.
    Pergunte ao FixBot
    Comentar
  8. Stapler Spring Replacement: passo 8, imagem 1 %32
    • Hook one end of the new spring onto the pusher's hook.
    Pergunte ao FixBot
    Comentar
  9. Stapler Spring Replacement: passo 9, imagem 1 %32
    • Clamp the pusher's hook closed using your thumb.
    Pergunte ao FixBot
    Comentar
  10. Stapler Spring Replacement: passo 10, imagem 1 %32
    • Thread the other end of the new spring through the top rectangular hole toward the back.
    Pergunte ao FixBot
    Comentar
  11. Stapler Spring Replacement: passo 11, imagem 1 %32
    • Thread the new spring through the bottom hole, bringing the end of spring toward you.
    • The spring should create a loop when done threading.
    Pergunte ao FixBot
    Comentar
  12. Stapler Spring Replacement: passo 12, imagem 1 %32 Stapler Spring Replacement: passo 12, imagem 2 %32
    • Hook the new spring to the hook on the inside of the handle's metal part.
    Pergunte ao FixBot
    Comentar
  13. Stapler Spring Replacement: passo 13, imagem 1 %32 Stapler Spring Replacement: passo 13, imagem 2 %32
    • Press the metal part down with your thumbs until it aligns with the hammer's hole.
    Pergunte ao FixBot
    Comentar
  14. Stapler Spring Replacement: passo 14, imagem 1 %32 Stapler Spring Replacement: passo 14, imagem 2 %32
    • Reattach the hammer back onto the metal part.
    Pergunte ao FixBot
    Comentar
  15. Stapler Spring Replacement: passo 15, imagem 1 %32 Stapler Spring Replacement: passo 15, imagem 2 %32
    • Close the handle until it clicks back into place.
    • Be careful not to staple your fingers when closing the stapler.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
14Comentários do guia
Just what I needed. Thank you! Super clear
Daniela Labra - Responder Compartilhar
Can I replace the black rubber piece that goes on my swingling desk top stapler 70 sheet it came off and my dog chewed it up.
Edith Corkell - Responder Compartilhar
fron this sale ski o donde venden los repuestos de esta engrapadora en Venezuela gran caracas
Romulo - Responder Compartilhar
Where do I obtain a replacement spring for this stapler?
John Drake - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 137
Últimos 7 dias: 1,024
Últimos 30 dias: 5,043
Ao todo: 308,455
