Ir para o conteúdo principal
Stapler Maintenance
    1. Stapler Maintenance, Open & Identify: passo 1, imagem 1 %32 Stapler Maintenance, Open & Identify: passo 1, imagem 2 %32
      • Be careful while handling staples or any sharp object in general.
      • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
      • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
      Pergunte ao FixBot
      Comentar
    2. Stapler Maintenance, Insert Staples: passo 2, imagem 1 %32 Stapler Maintenance, Insert Staples: passo 2, imagem 2 %32
      • Get a cluster of staples and carefully place it in the carrier.
      • Make sure there is enough room for the pusher to contact the staples.
      • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
      Pergunte ao FixBot
      Comentar
    3. Stapler Maintenance: passo 3, imagem 1 %32
      • Don’t staple your hand, or anyone else for that matter.
      • Congratulations! You have successfully replaced staples in your stapler.
      Pergunte ao FixBot
      Comentar
Conclusão
10 outras pessoas executaram este guia.
2Comentários do guia
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Responder Compartilhar
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 91
Últimos 7 dias: 538
Últimos 30 dias: 2,761
Ao todo: 59,106
