Ir para o conteúdo principal
Sprout Channel Cubby Speaker Replacement
O que você precisa
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: passo 1, imagem 1 %32 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: passo 1, imagem 2 %32
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
    Pergunte ao FixBot
    Comentar
  2. Sprout Channel Cubby Speaker Replacement, Speaker: passo 2, imagem 1 %32 Sprout Channel Cubby Speaker Replacement, Speaker: passo 2, imagem 2 %32
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
    Pergunte ao FixBot
    Comentar
  3. Sprout Channel Cubby Speaker Replacement: passo 3, imagem 1 %32 Sprout Channel Cubby Speaker Replacement: passo 3, imagem 2 %32
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 14-101, Meier Fall 2015 Membro de USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Membros
Autoria de 12 guias
2Comentários do guia
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Responder Compartilhar
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 43
Ao todo: 1,552
