Ir para o conteúdo principal
Spin Master Boxer Wheel Gears Replacement
O que você precisa
    1. Spin Master Boxer Wheel Gears Replacement, Robot Screen: passo 1, imagem 1 %32
      • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
      Pergunte ao FixBot
      Comentar
    2. Spin Master Boxer Wheel Gears Replacement: passo 2, imagem 1 %32
      • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
      Pergunte ao FixBot
      Comentar
    3. Spin Master Boxer Wheel Gears Replacement: passo 3, imagem 1 %32
      • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
      Pergunte ao FixBot
      Comentar
    4. Spin Master Boxer Wheel Gears Replacement: passo 4, imagem 1 %32 Spin Master Boxer Wheel Gears Replacement: passo 4, imagem 2 %32
      • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
      • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
      Pergunte ao FixBot
      Comentar
    5. Spin Master Boxer Wheel Gears Replacement: passo 5, imagem 1 %32
      • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
      Pergunte ao FixBot
      Comentar
    1. Spin Master Boxer Wheel Gears Replacement, Robot Wheel Gears: passo 6, imagem 1 %32
      • Place robot on back so that the sensors are facing up.
      Pergunte ao FixBot
      Comentar
    2. Spin Master Boxer Wheel Gears Replacement: passo 7, imagem 1 %32 Spin Master Boxer Wheel Gears Replacement: passo 7, imagem 2 %32
      • Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
      • There are wires attached to each set of wheels, so be careful not to rip them apart.
      • Repeat the process for the right set of wheels.
      Pergunte ao FixBot
      Comentar
    3. Spin Master Boxer Wheel Gears Replacement: passo 8, imagem 1 %32 Spin Master Boxer Wheel Gears Replacement: passo 8, imagem 2 %32
      • Use the Phillips #00 Screwdriver to remove the 3mm screw that connect the black wheels to the gears.
      • You will have to go through the black wheel to unscrew some of the screws.
      Pergunte ao FixBot
      Comentar
    4. Spin Master Boxer Wheel Gears Replacement: passo 9, imagem 1 %32 Spin Master Boxer Wheel Gears Replacement: passo 9, imagem 2 %32 Spin Master Boxer Wheel Gears Replacement: passo 9, imagem 3 %32
      • Grip wheel, and gently pull up, to separate white gear casing into its front and back panel.
      Pergunte ao FixBot
      Comentar
    5. Spin Master Boxer Wheel Gears Replacement: passo 10, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, grip defective gear, and pull up and out of gear system to replace.
      Pergunte ao FixBot
      Comentar
Conclusão
Lauren Roide
Membro desde: 04/16/19
769 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G1, Maness Spring 2019 Membro de Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Membros
Autoria de 10 guias
3Comentários do guia
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Javier Perez - Responder Compartilhar
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Jerome Carbonneaux - Responder Compartilhar
Do you know its spec to buy a new one?
Realy sorry...
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 14
Últimos 30 dias: 42
Ao todo: 4,513
