Ir para o conteúdo principal
Spin Master Boxer Remote Trigger Buttons Replacement
O que você precisa
  1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: passo 1, imagem 1 %32
    • Lay the remote flat on your work space, with joysticks facing you.
    Pergunte ao FixBot
    Comentar
  2. Spin Master Boxer Remote Trigger Buttons Replacement: passo 2, imagem 1 %32
    • Remove both joysticks by gripping under circular knob and gently pulling towards you.
    • The joysticks should detach without much effort.
    Pergunte ao FixBot
    Comentar
  3. Spin Master Boxer Remote Trigger Buttons Replacement: passo 3, imagem 1 %32
    • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
    • Remove the batteries from the remote and set it to side.
    • Use the same screwdriver to remove all four 4mm screws on back panel.
    Pergunte ao FixBot
    Comentar
  4. Spin Master Boxer Remote Trigger Buttons Replacement: passo 4, imagem 1 %32 Spin Master Boxer Remote Trigger Buttons Replacement: passo 4, imagem 2 %32
    • Insert the Jimmy in between the top panel and the bottom panel.
    • Gently use the Jimmy to separate both plastic panels from each other.
    • Pull the panels apart and set bottom piece on workbench.
    Pergunte ao FixBot
    Comentar
  5. Spin Master Boxer Remote Trigger Buttons Replacement: passo 5, imagem 1 %32 Spin Master Boxer Remote Trigger Buttons Replacement: passo 5, imagem 2 %32
    • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
    • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
    Pergunte ao FixBot
    Comentar
Conclusão
Lauren Roide
Membro desde: 04/16/19
769 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G1, Maness Spring 2019 Membro de Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,290
