Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn over the device.
Peel the silicone feet up to remove.
Remove all eight of the 11 mm Phillips screws from the bottom of the device.
Remove the bottom panel speaker using an iFixit opening tool.
Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
Remove the plastic panel.
Remove the three screws that are holding the speaker down.
Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
Remove the speaker from the motherboard.
Remove the speaker ring.
Repeat Steps 5-7 with the other speaker.
Uma outra pessoa concluiu este guia.
