Ir para o conteúdo principal
Zenbre SoundBank Z3 Speaker Replacement
O que você precisa
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: passo 1, imagem 1 %32 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: passo 2, imagem 1 %32
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: passo 3, imagem 1 %32 Zenbre SoundBank Z3 Speaker Replacement: passo 3, imagem 2 %32
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: passo 4, imagem 1 %32 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: passo 4, imagem 2 %32 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: passo 4, imagem 3 %32
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: passo 5, imagem 1 %32 Zenbre SoundBank Z3 Speaker Replacement, Speakers: passo 5, imagem 2 %32
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: passo 6, imagem 1 %32 Zenbre SoundBank Z3 Speaker Replacement: passo 6, imagem 2 %32
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: passo 7, imagem 1 %32 Zenbre SoundBank Z3 Speaker Replacement: passo 7, imagem 2 %32
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Cherian Thomas
Membro desde: 03/25/16
334 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 469
