Ir para o conteúdo principal
Zenbre SoundBank Z3 Speaker Grill Replacement
O que você precisa
  1. Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: passo 1, imagem 1 %32 Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 2, imagem 1 %32
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 3, imagem 1 %32 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 3, imagem 2 %32
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: passo 4, imagem 1 %32 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: passo 4, imagem 2 %32 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: passo 4, imagem 3 %32
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: passo 5, imagem 1 %32 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: passo 5, imagem 2 %32 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: passo 5, imagem 3 %32
    • Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
    • Be careful not to rip out the speaker while taking out the screws
    • The same steps can be done on the other side of the speaker
  6. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 6, imagem 1 %32 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 6, imagem 2 %32 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 6, imagem 3 %32
    • First, remove the speaker from the motherboard, then remove the ring that held the speaker in place.
    • These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
    • How To Solder and Desolder Connections
  7. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 7, imagem 1 %32 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 7, imagem 2 %32
    • With the plastic ring removed, the speaker should slide out easily.
    • Be careful not remove other components in the speaker
    • This will expose the speaker grill
  8. Zenbre SoundBank Z3 Speaker Grill Replacement: passo 8, imagem 1 %32 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 8, imagem 2 %32 Zenbre SoundBank Z3 Speaker Grill Replacement: passo 8, imagem 3 %32
    • Now that the speaker has been removed, the plastic grill should be visible.
    • With a little bit of force they can be pushed out.
Conclusão
Equipe
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 514
