Ir para o conteúdo principal
Sophix TAB-730g Battery Replacement
O que você precisa
  1. Sophix TAB-730g Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  2. Sophix TAB-730g Battery Replacement: passo 2, imagem 1 %32
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  3. Sophix TAB-730g Battery Replacement: passo 3, imagem 1 %32
    • Desolder the two wires connecting the battery to the mother board.
  4. Sophix TAB-730g Battery Replacement: passo 4, imagem 1 %32
    • Gently pry the battery off the back of the device using some force.
    • There is adhesive keeping the battery attached so a decent amount of force may need to be applied.
Conclusão
JT Hiquet
Membro desde: 09/29/16
333 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 2-3, Harley Fall 2016 Membro de IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
Membros da 4
Autoria de 6 guias
Um comentário
[|how do you know if the problem is or is not the battery?]
Don Taylor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 368
