Ir para o conteúdo principal
Sony a7 Rear Disassembly Replacement
O que você precisa
    1. Sony a7 Rear Disassembly  Replacement, Rear Disassembly: passo 1, imagem 1 %32
      • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
      • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Sony a7 Rear Disassembly  Replacement: passo 2, imagem 1 %32 Sony a7 Rear Disassembly  Replacement: passo 2, imagem 2 %32 Sony a7 Rear Disassembly  Replacement: passo 2, imagem 3 %32
      • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Sony a7 Rear Disassembly  Replacement: passo 3, imagem 1 %32
      • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Sony a7 Rear Disassembly  Replacement: passo 4, imagem 1 %32 Sony a7 Rear Disassembly  Replacement: passo 4, imagem 2 %32
      • Remove the four M 1.5x2mm screws.
      Pergunte ao FixBot
      Comentar
    5. Sony a7 Rear Disassembly  Replacement: passo 5, imagem 1 %32 Sony a7 Rear Disassembly  Replacement: passo 5, imagem 2 %32 Sony a7 Rear Disassembly  Replacement: passo 5, imagem 3 %32
      • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
      Pergunte ao FixBot
      Comentar
    6. Sony a7 Rear Disassembly  Replacement: passo 6, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Using the blunt tweezers, remove the blue ribbon cable.
      • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
      Pergunte ao FixBot
      Comentar
    7. Sony a7 Rear Disassembly  Replacement: passo 7, imagem 1 %32 Sony a7 Rear Disassembly  Replacement: passo 7, imagem 2 %32
      • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
      Pergunte ao FixBot
      Comentar
    8. Sony a7 Rear Disassembly  Replacement: passo 8, imagem 1 %32 Sony a7 Rear Disassembly  Replacement: passo 8, imagem 2 %32 Sony a7 Rear Disassembly  Replacement: passo 8, imagem 3 %32
      • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    9. Sony a7 Rear Disassembly  Replacement: passo 9, imagem 1 %32
      • Lift the metal plate and LCD screen away from the camera body.
      Pergunte ao FixBot
      Comentar
    10. Sony a7 Rear Disassembly  Replacement: passo 10, imagem 1 %32
      • Detach the amber ribbon cable from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 96
Ao todo: 9,694
