Ir para o conteúdo principal
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
O que você precisa
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: passo 1, imagem 1 %32 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: passo 1, imagem 2 %32 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: passo 1, imagem 3 %32
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Phillips #0 Screwdriver
    $5.49
    Comprar
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 3, imagem 1 %32 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 3, imagem 2 %32 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 3, imagem 3 %32
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 4, imagem 1 %32 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 4, imagem 2 %32 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 4, imagem 3 %32
    Heavy-Duty Spudger
    Comprar
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 5, imagem 1 %32 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 5, imagem 2 %32
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: passo 6, imagem 1 %32
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Conclusão
Chao Chen
Membro desde: 10/04/11
79 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-35, Amido Fall 2011 Membro de Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 5,618
