Ir para o conteúdo principal
Sony Xplod CDX-MP30 CD Drive Motherboard Replacement
O que você precisa
  1. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: passo 1, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: passo 1, imagem 2 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Front Panel: passo 1, imagem 3 %32
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Main Panels: passo 2, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, Main Panels: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Phillips #0 Screwdriver
    $5.49
    Comprar
  3. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 3, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 3, imagem 2 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 3, imagem 3 %32
    Phillips #1 Screwdriver
    $5.49
    Comprar
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 5, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 5, imagem 2 %32
    $5.49
    Comprar
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 6, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 6, imagem 2 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 6, imagem 3 %32
    $5.49
    Comprar
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 7, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 7, imagem 2 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 7, imagem 3 %32
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 8, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 8, imagem 2 %32
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 9, imagem 1 %32
    $5.49
    Comprar
  10. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 10, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 10, imagem 2 %32
    $5.49
    Comprar
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 11, imagem 1 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 11, imagem 2 %32 Sony Xplod CDX-MP30 CD Drive Motherboard Replacement: passo 11, imagem 3 %32
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 CD Drive Motherboard Replacement, CD Drive Motherboard: passo 12, imagem 1 %32
    • The CD Drive Motherboard is located on the under-side of the CD Drive itself.
    • Please refer to the iFixit soldering guide to remove the CD Drive Motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Daniel Johnson
Membro desde: 10/10/11
87 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-35, Amido Fall 2011 Membro de Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 3,219
