Ir para o conteúdo principal
Sony Xperia ZL Screen Replacement
O que você precisa
  1. Sony Xperia ZL Screen Replacement, Screen: passo 1, imagem 1 %32 Sony Xperia ZL Screen Replacement, Screen: passo 1, imagem 2 %32
    • Open the small cover on the bottom of the rear cover.
    • Peel back the sticker under the cover to reveal two screws.
    • Remove the two screws from the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. Sony Xperia ZL Screen Replacement: passo 2, imagem 1 %32
    • Once the two screws have been removed. Take the prying tool to pry off the back cover of the phone. Next take a JIS J00 screwhead and unscrew the 5 screws that are located in the photo.
    Pergunte ao FixBot
    Comentar
  3. Sony Xperia ZL Screen Replacement: passo 3, imagem 1 %32
    • After the screws have been taken out, disconnect the connectors circled to the left using a small plastic prying tool.
    • Carefully pry connectors making sure to always use a plastic prying tool. Using a metal prying tool could damage the battery and potentially cause a fire.
    Pergunte ao FixBot
    Comentar
  4. Sony Xperia ZL Screen Replacement: passo 4, imagem 1 %32
    • The last connector is located under the black sticker. Peel back the black sticker and disconnect the last connector.
    Pergunte ao FixBot
    Comentar
  5. Sony Xperia ZL Screen Replacement: passo 5, imagem 1 %32
    • With all the connectors removed we can safely pry off the camera and all of its components using a plastic prying tool.
    Pergunte ao FixBot
    Comentar
  6. Sony Xperia ZL Screen Replacement: passo 6, imagem 1 %32
    • Removing the camera and its components makes the electrical panel easily come off. Gently pry off the electrical panel.
    Pergunte ao FixBot
    Comentar
  7. Sony Xperia ZL Screen Replacement: passo 7, imagem 1 %32
    • Take a small plastic prying tool and pry out the battery. The battery has adhesive tape that connects it to the phone which can make it difficult to pry out. Make sure to try prying from different angles of the battery.
    Pergunte ao FixBot
    Comentar
  8. Sony Xperia ZL Screen Replacement: passo 8, imagem 1 %32
    • With the battery gone, we next pry off the plastic covering that is located at the top of the phone using a metal spatula.
    Pergunte ao FixBot
    Comentar
  9. Sony Xperia ZL Screen Replacement: passo 9, imagem 1 %32
    • Once the plastic covering is removed, the front camera and signal receptor can be taken off the phone. You should use the prying spatula to remove these two items. Be careful with prying out the signal receptor because it has adhesive tape underneath.
    Pergunte ao FixBot
    Comentar
  10. Sony Xperia ZL Screen Replacement: passo 10, imagem 1 %32
    • Next pry off the long plastic piece that goes around the perimeter of the left side of the phone. This part contains the volume and power button. The little component where the camera goes will need to be removed. Be careful when removing the front camera components because there is adhesive tape under it.
    Pergunte ao FixBot
    Comentar
  11. Sony Xperia ZL Screen Replacement: passo 11, imagem 1 %32
    • Next take a small prying tool to separate the glass screen and the frame around the screen. In most procedures the front screen will crack during this step, but luckily our's didn't. It is it okay if the screen cracks, just make sure to pry off all the glass.
    • A good tip would be to pry into the spots located in the picture.
    Pergunte ao FixBot
    Comentar
  12. Sony Xperia ZL Screen Replacement: passo 12, imagem 1 %32
    • Once you lift the glass, carefully pry off the adhesive tape around the edges of the phone. Once it has been taken off, carefully remove the screen from the frame and make sure the digitizer that is connected to the screen gets carefully taken out.
    • The digitizer will be taken out carefully through a small hole at the base of the phone. This needs to be taken out carefully.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Liam Kanaley
Membro desde: 11/03/15
433 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 Membro de UMass Dartmouth, Team 1-7, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G7
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 2,787
