Ir para o conteúdo principal
Sony Xperia Z2 Logic Board Replacement
O que você precisa
Vídeo de Apresentação
  1. Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: passo 1, imagem 1 %32 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: passo 1, imagem 2 %32 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: passo 1, imagem 3 %32
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
    Pergunte ao FixBot
    Comentar
  2. Sony Xperia Z2 Logic Board Replacement: passo 2, imagem 1 %32 Sony Xperia Z2 Logic Board Replacement: passo 2, imagem 2 %32 Sony Xperia Z2 Logic Board Replacement: passo 2, imagem 3 %32
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
    Pergunte ao FixBot
    Comentar
  3. Sony Xperia Z2 Logic Board Replacement: passo 3, imagem 1 %32 Sony Xperia Z2 Logic Board Replacement: passo 3, imagem 2 %32
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    Pergunte ao FixBot
    Comentar
  4. Sony Xperia Z2 Logic Board Replacement, Battery: passo 4, imagem 1 %32 Sony Xperia Z2 Logic Board Replacement, Battery: passo 4, imagem 2 %32 Sony Xperia Z2 Logic Board Replacement, Battery: passo 4, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  5. Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: passo 5, imagem 1 %32 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: passo 5, imagem 2 %32 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: passo 5, imagem 3 %32
    • Unscrew the screw and remove the Wi-Fi Antenna.
    Pergunte ao FixBot
    Comentar
  6. Sony Xperia Z2 Logic Board Replacement, Logic Board: passo 6, imagem 1 %32 Sony Xperia Z2 Logic Board Replacement, Logic Board: passo 6, imagem 2 %32
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
    Pergunte ao FixBot
    Comentar
  7. Sony Xperia Z2 Logic Board Replacement: passo 7, imagem 1 %32 Sony Xperia Z2 Logic Board Replacement: passo 7, imagem 2 %32 Sony Xperia Z2 Logic Board Replacement: passo 7, imagem 3 %32
    Pergunte ao FixBot
    Comentar
Conclusão
19 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
197.270 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
333 Membros
Autoria de 1.522 guias
3Comentários do guia
Hi
Do anyone knows where I can buy a logic board for Xperia Z2?
Johannes Stockinger - Responder Compartilhar
https://www.ebay.com/sch/i.html?_from=R4...
or I bought there
https://ru.aliexpress.com/wholesale?catI...
be careful to find cheaper price and for your model D6503 or D6563…
Alexander - Responder Compartilhar
Are you sure Phillips #00 is the correct size of screwdriver? I had difficulty getting one of the screws to turn (the screwdriver kept slipping), so I tried the other sizes in my iOpener Kit and found that the PH#000 seemed to fit them better, and that screw came straight out with it.
Edward Millen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 45
Ao todo: 19,291
