Introdução
If your device has a cracked or unresponsive touchscreen, you may need to replace your LCD touchscreen on your Sony Xperia Z1s device. In this guide, you will learn how to replace your Sony Xperia Z1s screen so that you may get the best performance out of your device.
Before beginning this guide, turn off your phone completely and remove it from any external power source.
Warning: Removing the back cover and screen without properly sealing the phone with new adhesive will make it no longer waterproof.
O que você precisa
Insert the opening pick in the crease between the rear cover and the body of the phone.
Pry along the edge to lift and remove the back cover.
Use the opening pick to pry off the camera flex cable.
Continue to lift the flex cable upward until the camera pops out.
Using the T4 Torx screwdriver, unscrew the single 5 mm screw from the bottom left corner of the loudspeaker cover.
Uma outra pessoa concluiu este guia.
