Ir para o conteúdo principal
Sony Xperia Z1s Rear Camera Replacement
O que você precisa
  1. Sony Xperia Z1s Rear Camera Replacement, Rear Camera: passo 1, imagem 1 %32
    • Insert the opening pick in the crease between the body of the phone and the phone's back cover.
    • Slide the opening pick around the crease until the back cover releases from the phone.
  2. Sony Xperia Z1s Rear Camera Replacement: passo 2, imagem 1 %32
    • Using the T4 Torx screwdriver, remove the five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Rear Camera Replacement: passo 3, imagem 1 %32
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Rear Camera Replacement: passo 4, imagem 1 %32
    • Use the opening pick to pry off the camera flex cable.
  5. Sony Xperia Z1s Rear Camera Replacement: passo 5, imagem 1 %32
    • Use the opening pick to lift the camera out of the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Amanda Simmons
Membro desde: 09/28/21
148 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 4-4, Hunter Fall 2021 Membro de Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 138
