Ir para o conteúdo principal
Sony Xperia Z1s Charging Port Replacement
O que você precisa
  1. Sony Xperia Z1s Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
  2. Sony Xperia Z1s Charging Port Replacement: passo 2, imagem 1 %32
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Charging Port Replacement: passo 3, imagem 1 %32
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Charging Port Replacement: passo 4, imagem 1 %32
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
  5. Sony Xperia Z1s Charging Port Replacement: passo 5, imagem 1 %32
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
  6. Sony Xperia Z1s Charging Port Replacement, Motherboard: passo 6, imagem 1 %32
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
  7. Sony Xperia Z1s Charging Port Replacement: passo 7, imagem 1 %32
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
  8. Sony Xperia Z1s Charging Port Replacement: passo 8, imagem 1 %32
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
  9. Sony Xperia Z1s Charging Port Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
  10. Sony Xperia Z1s Charging Port Replacement: passo 10, imagem 1 %32
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
  11. Sony Xperia Z1s Charging Port Replacement, Charging Port: passo 11, imagem 1 %32
  12. Sony Xperia Z1s Charging Port Replacement: passo 12, imagem 1 %32
    Comprar
    • Use a pair of tweezers to remove the charging port from the device.
Conclusão
Jacob Willey
Membro desde: 09/28/21
85 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 4-4, Hunter Fall 2021 Membro de Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 171
