Ir para o conteúdo principal
Sony Xperia Z1 Compact Rear Camera Replacement
O que você precisa
  1. Sony Xperia Z1 Compact Rear Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Heat along the edges of the back cover using a heat gun to soften the glue.
    Pergunte ao FixBot
    Comentar
  2. Sony Xperia Z1 Compact Rear Camera Replacement: passo 2, imagem 1 %32
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
    Pergunte ao FixBot
    Comentar
  3. Sony Xperia Z1 Compact Rear Camera Replacement: passo 3, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 3, imagem 2 %32
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
    Pergunte ao FixBot
    Comentar
  4. Sony Xperia Z1 Compact Rear Camera Replacement, Battery: passo 4, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement, Battery: passo 4, imagem 2 %32
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
    Pergunte ao FixBot
    Comentar
  5. Sony Xperia Z1 Compact Rear Camera Replacement: passo 5, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 5, imagem 2 %32
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Sony Xperia Z1 Compact Rear Camera Replacement: passo 6, imagem 1 %32
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
    Pergunte ao FixBot
    Comentar
  7. Sony Xperia Z1 Compact Rear Camera Replacement: passo 7, imagem 1 %32
    • Remove the battery from the device
    Pergunte ao FixBot
    Comentar
  8. Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: passo 8, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: passo 8, imagem 2 %32
    • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Sony Xperia Z1 Compact Rear Camera Replacement: passo 9, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 9, imagem 2 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 9, imagem 3 %32
    • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
    Pergunte ao FixBot
    Comentar
  10. Sony Xperia Z1 Compact Rear Camera Replacement: passo 10, imagem 1 %32
    • Remove the back frame.
    Pergunte ao FixBot
    Comentar
  11. Sony Xperia Z1 Compact Rear Camera Replacement: passo 11, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 11, imagem 2 %32
    • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
    Pergunte ao FixBot
    Comentar
  12. Sony Xperia Z1 Compact Rear Camera Replacement: passo 12, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 12, imagem 2 %32
    • Remove the external speaker.
    Pergunte ao FixBot
    Comentar
  13. Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: passo 13, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: passo 13, imagem 2 %32
    • Remove the square rubber gasket from the camera using the plastic spudger.
    Pergunte ao FixBot
    Comentar
  14. Sony Xperia Z1 Compact Rear Camera Replacement: passo 14, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 14, imagem 2 %32
    • Remove the black plastic corner still holding in the motherboard.
    Pergunte ao FixBot
    Comentar
  15. Sony Xperia Z1 Compact Rear Camera Replacement: passo 15, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 15, imagem 2 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 15, imagem 3 %32
    • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
    Pergunte ao FixBot
    Comentar
  16. Sony Xperia Z1 Compact Rear Camera Replacement: passo 16, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 16, imagem 2 %32 Sony Xperia Z1 Compact Rear Camera Replacement: passo 16, imagem 3 %32
    • Remove the motherboard from the device.
    • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
    Pergunte ao FixBot
    Comentar
  17. Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: passo 17, imagem 1 %32 Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: passo 17, imagem 2 %32
    • Disconnect the camera from the motherboard using a spudger.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
The trouble is that the headphones jack and the monitor cables are unplugged when removing the motherboard and I do not think it is possible to plug them back in from the back side of the phone. I think the monitor needs to be removed for them to be plugged from the front.
natuk - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 39
Ao todo: 1,245
