Ir para o conteúdo principal
Sony Xperia Z Ultra Screen Replacement
O que você precisa
  1. Sony Xperia Z Ultra Screen Replacement, Battery: passo 1, imagem 1 %32
    • Use the small suction cup to lift the back panel:
    • Press the small suction cup on to the middle of the back panel.
    Pergunte ao FixBot
    Comentar
  2. Sony Xperia Z Ultra Screen Replacement: passo 2, imagem 1 %32
    • While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
    • While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
    • Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
    Pergunte ao FixBot
    Comentar
  3. Sony Xperia Z Ultra Screen Replacement: passo 3, imagem 1 %32
    • Remove the back panel by pulling the small suction cup upwards.
    Pergunte ao FixBot
    Comentar
  4. Sony Xperia Z Ultra Screen Replacement: passo 4, imagem 1 %32
    • Remove the following six screws with a Phillips #000 screwdriver:
    • five silver 2.1 mm screws
    • one gold 3.1 mm screw
    Pergunte ao FixBot
    Comentar
  5. Sony Xperia Z Ultra Screen Replacement: passo 5, imagem 1 %32
    • Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
    Pergunte ao FixBot
    Comentar
  6. Sony Xperia Z Ultra Screen Replacement: passo 6, imagem 1 %32
    • Use care to remove the motherboard shield, as it may break. The motherboard shield is made of a very thin plastic.
    • Remove the motherboard shield by lifting the lower end upwards first.
    Pergunte ao FixBot
    Comentar
  7. Sony Xperia Z Ultra Screen Replacement: passo 7, imagem 1 %32 Sony Xperia Z Ultra Screen Replacement: passo 7, imagem 2 %32
    • Detach the battery connection cable by prying it upward with the spudger.
    Pergunte ao FixBot
    Comentar
  8. Sony Xperia Z Ultra Screen Replacement: passo 8, imagem 1 %32
    • Pry the upper end of the antenna upwards with the spudger.
    Pergunte ao FixBot
    Comentar
  9. Sony Xperia Z Ultra Screen Replacement: passo 9, imagem 1 %32
    • Detach the antenna by pulling the upper end upwards and outwards.
    Pergunte ao FixBot
    Comentar
  10. Sony Xperia Z Ultra Screen Replacement: passo 10, imagem 1 %32
    • Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
    Pergunte ao FixBot
    Comentar
  11. Sony Xperia Z Ultra Screen Replacement: passo 11, imagem 1 %32
    • Remove the battery from the phone.
    Pergunte ao FixBot
    Comentar
  12. Sony Xperia Z Ultra Screen Replacement, Headphone Jack: passo 12, imagem 1 %32
    • Use care to remove the headphone jack connection, as it may snap if excessive force is used. The headphone jack connection is extremely thin.
    • Detach the headphone jack connection by prying it upwards with the spudger.
    Pergunte ao FixBot
    Comentar
  13. Sony Xperia Z Ultra Screen Replacement: passo 13, imagem 1 %32
    • Use care to remove the earphone jack connection, as it may snap if excessive force is used. The earphone jack connection is extremely thin.
    • Detach the earphone jack connection by prying it upwards with the spudger.
    Pergunte ao FixBot
    Comentar
  14. Sony Xperia Z Ultra Screen Replacement: passo 14, imagem 1 %32 Sony Xperia Z Ultra Screen Replacement: passo 14, imagem 2 %32
    • Disconnect the ribbon cable at the bottom right of the motherboard. (It's shown tucked under the motherboard in this photo, which is incorrect—don't do this!)
    Pergunte ao FixBot
    Comentar
  15. Sony Xperia Z Ultra Screen Replacement: passo 15, imagem 1 %32
    • Detach the upper end of the motherboard by pulling the top end upwards.
    Pergunte ao FixBot
    Comentar
  16. Sony Xperia Z Ultra Screen Replacement: passo 16, imagem 1 %32 Sony Xperia Z Ultra Screen Replacement: passo 16, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the yellow clip that secures the headphone jack slot with a pair of tweezers.
    • The motherboard is still attached but moved outside of the image in order for the components being worked on to be more visible.
    Pergunte ao FixBot
    Comentar
  17. Sony Xperia Z Ultra Screen Replacement: passo 17, imagem 1 %32 Sony Xperia Z Ultra Screen Replacement: passo 17, imagem 2 %32 Sony Xperia Z Ultra Screen Replacement: passo 17, imagem 3 %32
    • Push the red stopper of the headphone jack connection through the plastic tunnel with the spudger.
    • Use care to guide the head phone jack connection through the plastic tunnel, as it may deform and break if forceful or sudden movements is used. The headphone jack is made of a very thin plastic.
    • While holding the back end of the headphone jack connection, grasp the headphone jack connection with the pair of tweezers and guide it through the plastic tunnel.
    • Remove the headphone jack connection from the device.
    Pergunte ao FixBot
    Comentar
  18. Sony Xperia Z Ultra Screen Replacement, Screen: passo 18, imagem 1 %32
    • Using the spudger, detach the listening speaker from the motherboard by prying it upwards.
    • If necessary, use tweezers.
    Pergunte ao FixBot
    Comentar
  19. Sony Xperia Z Ultra Screen Replacement: passo 19, imagem 1 %32
    • Slide the spudger below the orange ribbon to remove it from the reflective backing.
    • The ribbon is very thin and breakable, use care.
    Pergunte ao FixBot
    Comentar
  20. Sony Xperia Z Ultra Screen Replacement: passo 20, imagem 1 %32
    • Use iOpener on the screen of your device to loosen the adhesive below the screen.
    • If unfamiliar with using an iOpener, click here for specific instructions.
    • If you do not have access to an iOpener Kit, you may use a hair dryer on its lowest setting . Heat evenly around the screen edges at a 45 degree angle for 25-30 seconds .
    Pergunte ao FixBot
    Comentar
  21. Sony Xperia Z Ultra Screen Replacement: passo 21, imagem 1 %32
    • Once the screen is heated sufficiently, press the small suction cup to the center of the screen.
    Pergunte ao FixBot
    Comentar
  22. Sony Xperia Z Ultra Screen Replacement: passo 22, imagem 1 %32 Sony Xperia Z Ultra Screen Replacement: passo 22, imagem 2 %32
    • Beginning at the corner of the screen, insert the opening pick into the space between the screen and casing.
    • While pulling on the small suction cup, gradually slide the pick along the edges of the screen until it is separated from the casing.
    • Due to the adhesive, resistance will be felt when sliding the opening pick.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble the device, follow these instructions in reverse order.
31 outras pessoas executaram este guia.
Aaron Quinn
Membro desde: 10/01/15
930 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-6, Maness Fall 2015 Membro de Cal Poly, Team 4-6, Maness Fall 2015
CPSU-MANESS-F15S4G6
4 Membros
Autoria de 10 guias
14Comentários do guia
The directions are wrong. The steps are not in order. The ribbon cable will rip on you when you remove the battery. Do not attempt.
Patrick Johnson - Responder Compartilhar
Ribbon cable will not be ripped when removing battery, check to make sure you have carefully broken the adhesive seal between the battery and phone housing.
Aaron Quinn - Responder Compartilhar
There is absolutely no reason to take out anything other than the battery and the small parts at the bottom of the phone if you are replacing the display assembly on this device. Taking out anything at the top is a waste of time, and a risk to the motherboard. The metal shield at the bottom is really the only thing you need to remove to get to the digitizer connector. Taking anything else out results in wasted time and additional risk to damage of other components.
Wichita uBreakiFix - Responder Compartilhar
A hundred times this. The button flex cables on Sony phones are very easy to damage, and there is absolutely no reason to remove them just to replace the display. Unless your display assembly came with a complete frame. Then you have bigger worries, and this guide is incomplete.
Ties Koot - Responder Compartilhar
Great instructions thanks and it would be even greater if you mentioned that you didnt have to remove flex cables for volume keys or even motherboard
Kiwi Phone Repairs NZ - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 64
Ao todo: 29,625
