Ir para o conteúdo principal
Sony Xperia XZ Premium Front Camera Replacement
O que você precisa
  1. Sony Xperia XZ Premium Front Camera Replacement, Back Panel: passo 1, imagem 1 %32
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
  2. Sony Xperia XZ Premium Front Camera Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Front Camera Replacement: passo 3, imagem 1 %32
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Front Camera Replacement, Front Camera: passo 4, imagem 1 %32
    • Remove the two bottom left 3.9 mm Phillips #000 screws.
  5. Sony Xperia XZ Premium Front Camera Replacement: passo 5, imagem 1 %32
    • Insert the spudger under the bottom left frame and lift, try to lift vertically to wedge it out.
  6. Sony Xperia XZ Premium Front Camera Replacement: passo 6, imagem 1 %32
    • Grab hold of the bottom left frame and lift out carefully.
  7. Sony Xperia XZ Premium Front Camera Replacement: passo 7, imagem 1 %32
    • Insert a spudger under the tab above the camera and lift to disconnect it.
  8. Sony Xperia XZ Premium Front Camera Replacement: passo 8, imagem 1 %32
    • Grab hold of the tab with your fingers.
  9. Sony Xperia XZ Premium Front Camera Replacement: passo 9, imagem 1 %32
    • Lift the camera from the phone by the tab.
Conclusão
Gelene Amog
Membro desde: 04/18/18
1.165 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G2, Livingston Spring 2018 Membro de Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
Membros da 5
Autoria de 16 guias
Um comentário
The name of this tutorial is incorrect.
Gavin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 2,162
