Ir para o conteúdo principal
Sony Xperia XZ Premium Battery Replacement
O que você precisa
  1. Sony Xperia XZ Premium Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
  2. Sony Xperia XZ Premium Battery Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Battery Replacement: passo 3, imagem 1 %32
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Battery Replacement, Frame: passo 4, imagem 1 %32
    • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
  5. Sony Xperia XZ Premium Battery Replacement: passo 5, imagem 1 %32 Sony Xperia XZ Premium Battery Replacement: passo 5, imagem 2 %32
    • Remove nine 3.9mm Phillips #000 screws.
    • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
    • When unscrewing, remember "Left Loosey, Righty Tighty!"
  6. Sony Xperia XZ Premium Battery Replacement: passo 6, imagem 1 %32
    • Place the spudger under the top left corner frame piece and lift to loosen.
  7. Sony Xperia XZ Premium Battery Replacement: passo 7, imagem 1 %32
    • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
  8. Sony Xperia XZ Premium Battery Replacement: passo 8, imagem 1 %32
    • Place the spudger under the bottom left frame piece and lift to loosen it.
  9. Sony Xperia XZ Premium Battery Replacement: passo 9, imagem 1 %32
    • Grab hold of bottom left frame piece with your fingers and lift gently.
    • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
  10. Sony Xperia XZ Premium Battery Replacement: passo 10, imagem 1 %32
    • Place the spudger under the top right frame piece and lift to loosen it.
  11. Sony Xperia XZ Premium Battery Replacement: passo 11, imagem 1 %32
    • Grab hold of the top right frame piece with your fingers and lift.
  12. Sony Xperia XZ Premium Battery Replacement, Motherboard: passo 12, imagem 1 %32
    • Insert your nail under the top left connector and push to disconnect it.
  13. Sony Xperia XZ Premium Battery Replacement: passo 13, imagem 1 %32
    • Grab hold of the metal part of the connector with your fingers and lift.
  14. Sony Xperia XZ Premium Battery Replacement: passo 14, imagem 1 %32
    • Insert your nail under the metal part of the bottom left connector.
  15. Sony Xperia XZ Premium Battery Replacement: passo 15, imagem 1 %32
    • Push the bottom left connector with your finger to disconnect it.
  16. Sony Xperia XZ Premium Battery Replacement: passo 16, imagem 1 %32
    • Insert your nail under the center topmost connector and push to loosen it.
  17. Sony Xperia XZ Premium Battery Replacement: passo 17, imagem 1 %32
    • Grab hold of the top connector with your fingers and lift to disconnect it.
  18. Sony Xperia XZ Premium Battery Replacement: passo 18, imagem 1 %32
    • Insert your nail under the metal tab of the connector above the battery and push to loosen it.
  19. Sony Xperia XZ Premium Battery Replacement: passo 19, imagem 1 %32
    • Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
  20. Sony Xperia XZ Premium Battery Replacement: passo 20, imagem 1 %32
    • Insert spudger in the gap above the battery and lift to loosen the motherboard.
    • Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
  21. Sony Xperia XZ Premium Battery Replacement: passo 21, imagem 1 %32
    • Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
  22. Sony Xperia XZ Premium Battery Replacement: passo 22, imagem 1 %32
    • Grab hold of the motherboard with your fingers and lift it out of the phone gently.
  23. Sony Xperia XZ Premium Battery Replacement, Battery: passo 23, imagem 1 %32
    • Insert the spudger under the battery and push to loosen it from the adhesive.
    • The adhesive under the battery is very strong and is concentrated on the very left and very right underneath the battery. You may have to use a good amount of force to dislodge it. Do not worry if you hear cracking noises as you dislodge it.
  24. Sony Xperia XZ Premium Battery Replacement: passo 24, imagem 1 %32
    • Insert and push the spudger underneath the other sides of the battery to further loosen it.
  25. Sony Xperia XZ Premium Battery Replacement: passo 25, imagem 1 %32
    Plastic Cards
    $2.99
    Comprar
    • Use the plastic card to push under the battery to further remove the adhesive.
  26. Sony Xperia XZ Premium Battery Replacement: passo 26, imagem 1 %32
    • Lift the battery with your fingers and pull it out.
    • You will need adhesive to reassemble the phone.
Conclusão
8 outras pessoas executaram este guia.
Gelene Amog
Membro desde: 04/18/18
1.165 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G2, Livingston Spring 2018 Membro de Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
Membros da 5
Autoria de 16 guias
4 comentários
個人的意見を書きます。まず最初にこの手順はあくまでもバッテリーを取り外すだけの手順書です。作成者がこの手順書を部分的に書き直さない限り作業事故によっては「ボリューム パワースイッチフレックスケーブル」、「nfcアンテナ」、「イヤホンジャック フレックスケーブル」、最悪「マザーボード」をも交換する羽目になる事を視野に入れて作業した方がいいです。それらの注意書きがないのが残念です。
「ボリュームパワースイッチフレックスケーブル」と「nfcアンテナ」はバッテリーに接着されています。特にnfcアンテナの黒い部分は恐らくアンテナの一部と思われ奇麗に剝がそうとしても絶対に破損しますので交換必須です。
Hideo Otsuka - Responder
貴重なご意見、ありがとうございました。
Midori Doi -
手順ありがとうございます。
手順25の前後でで左上側のコネクタを外す手順がなかったので見事に切りました。
他、海外動画と比較していくつか手順がすっ飛んでたので、注意書きはした方がよいと思いました。
wabi - Responder
詳細を報告いただきありがとうございました。手順25の前後の作業については修理ガイド担当者に付け足しの必要を伝えておきます。コネクタを破損させてしまい申し訳ありません。少し時間がかかるかもしれませんが、貴重な情報は英語と日本語の修理ガイドに反映させていただきます。御礼まで。
Midori Doi -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 96
Últimos 30 dias: 433
Duração total: 28,449
