Introdução
This guide is for the replacement of the USB-C module for the Sony Xperia XA1. It is common that after some time the USB-C receiver can go bad.
Before using this guide to replace the headphone jack, be sure to check out the troubleshooting page to ensure the speaker needs to be replaced.
O que você precisa
Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
Use a plastic opening tool to lift the battery connector.
Lift the flaps on both sides of the battery.
Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
