Ir para o conteúdo principal
Sony Xperia XA1 Speaker Replacement
O que você precisa
  1. Sony Xperia XA1 Speaker Replacement, Phone Back Cover: passo 1, imagem 1 %32 Sony Xperia XA1 Speaker Replacement, Phone Back Cover: passo 1, imagem 2 %32 Sony Xperia XA1 Speaker Replacement, Phone Back Cover: passo 1, imagem 3 %32
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Speaker Replacement, Speaker: passo 2, imagem 1 %32 Sony Xperia XA1 Speaker Replacement, Speaker: passo 2, imagem 2 %32 Sony Xperia XA1 Speaker Replacement, Speaker: passo 2, imagem 3 %32
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
  3. Sony Xperia XA1 Speaker Replacement: passo 3, imagem 1 %32 Sony Xperia XA1 Speaker Replacement: passo 3, imagem 2 %32 Sony Xperia XA1 Speaker Replacement: passo 3, imagem 3 %32
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
  4. Sony Xperia XA1 Speaker Replacement: passo 4, imagem 1 %32 Sony Xperia XA1 Speaker Replacement: passo 4, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
  5. Sony Xperia XA1 Speaker Replacement: passo 5, imagem 1 %32 Sony Xperia XA1 Speaker Replacement: passo 5, imagem 2 %32 Sony Xperia XA1 Speaker Replacement: passo 5, imagem 3 %32
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
Conclusão
Hunter
Membro desde: 02/14/23
349 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 110
