Ir para o conteúdo principal
Sony Xperia Sola Camera Module Replacement
O que você precisa
  1. Sony Xperia Sola Camera Module Replacement, Motherboard: passo 1, imagem 1 %32 Sony Xperia Sola Camera Module Replacement, Motherboard: passo 1, imagem 2 %32
    • Place phone down with screen side down and camera side facing up as shown.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
    Pergunte ao FixBot
    Comentar
  2. Sony Xperia Sola Camera Module Replacement: passo 2, imagem 1 %32 Sony Xperia Sola Camera Module Replacement: passo 2, imagem 2 %32 Sony Xperia Sola Camera Module Replacement: passo 2, imagem 3 %32
    • Remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
    Pergunte ao FixBot
    Comentar
  3. Sony Xperia Sola Camera Module Replacement: passo 3, imagem 1 %32 Sony Xperia Sola Camera Module Replacement: passo 3, imagem 2 %32
    • Pry off the bottom white cover by using the opening tool as a lever.
    Pergunte ao FixBot
    Comentar
  4. Sony Xperia Sola Camera Module Replacement: passo 4, imagem 1 %32 Sony Xperia Sola Camera Module Replacement: passo 4, imagem 2 %32
    • Remove the two additional screws using the Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Sony Xperia Sola Camera Module Replacement: passo 5, imagem 1 %32 Sony Xperia Sola Camera Module Replacement: passo 5, imagem 2 %32
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
    Pergunte ao FixBot
    Comentar
  6. Sony Xperia Sola Camera Module Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
    Pergunte ao FixBot
    Comentar
  7. Sony Xperia Sola Camera Module Replacement: passo 7, imagem 1 %32 Sony Xperia Sola Camera Module Replacement: passo 7, imagem 2 %32 Sony Xperia Sola Camera Module Replacement: passo 7, imagem 3 %32
    • Turn the phone onto its side. Insert a plastic opening tool into seam, and gently remove the cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
    Pergunte ao FixBot
    Comentar
  8. Sony Xperia Sola Camera Module Replacement: passo 8, imagem 1 %32
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
    Pergunte ao FixBot
    Comentar
  9. Sony Xperia Sola Camera Module Replacement: passo 9, imagem 1 %32 Sony Xperia Sola Camera Module Replacement: passo 9, imagem 2 %32
    • Use the tweezers to lift up on the circuit located at the top left.
    Pergunte ao FixBot
    Comentar
  10. Sony Xperia Sola Camera Module Replacement: passo 10, imagem 1 %32
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
    Pergunte ao FixBot
    Comentar
  11. Sony Xperia Sola Camera Module Replacement, Place the board as shown.: passo 11, imagem 1 %32
    • This will ensure easy removal of the camera module.
    Pergunte ao FixBot
    Comentar
  12. Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: passo 12, imagem 1 %32 Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: passo 12, imagem 2 %32 Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: passo 12, imagem 3 %32
    • Using the tweezers remove the camera from the power source.
    Pergunte ao FixBot
    Comentar
  13. Sony Xperia Sola Camera Module Replacement, Remove the camera module.: passo 13, imagem 1 %32
    • Pick up board and remove camera module. The module should seem to just pop out.
    Pergunte ao FixBot
    Comentar
Conclusão
Cary Drew
Membro desde: 09/25/14
866 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Brown Fall 2014 Membro de USF Tampa, Team 1-1, Brown Fall 2014
USFT-BROWN-F14S1G1
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 36
Ao todo: 728
