Ir para o conteúdo principal
Sony Xperia J Keyboard Module Replacement
O que você precisa
  1. Sony Xperia J Keyboard Module Replacement, External Features: passo 1, imagem 1 %32
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
  2. Sony Xperia J Keyboard Module Replacement: passo 2, imagem 1 %32
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
  3. Sony Xperia J Keyboard Module Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
  4. Sony Xperia J Keyboard Module Replacement: passo 4, imagem 1 %32 Sony Xperia J Keyboard Module Replacement: passo 4, imagem 2 %32 Sony Xperia J Keyboard Module Replacement: passo 4, imagem 3 %32
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
  5. Sony Xperia J Keyboard Module Replacement: passo 5, imagem 1 %32 Sony Xperia J Keyboard Module Replacement: passo 5, imagem 2 %32 Sony Xperia J Keyboard Module Replacement: passo 5, imagem 3 %32
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
  6. Sony Xperia J Keyboard Module Replacement: passo 6, imagem 1 %32
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
  7. Sony Xperia J Keyboard Module Replacement: passo 7, imagem 1 %32
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
  8. Sony Xperia J Keyboard Module Replacement, Removing Parts: passo 8, imagem 1 %32 Sony Xperia J Keyboard Module Replacement, Removing Parts: passo 8, imagem 2 %32
    • Remove adhesive black tape at the bottom left of the phone.
    • Then remove the clip by pulling it up and slide out the wide orange cable(seen in picture 2).
  9. Sony Xperia J Keyboard Module Replacement, Removing Parts: passo 9, imagem 1 %32
    • By using the tweezers, unclip the cable at the bottom right by pulling it up.
  10. Sony Xperia J Keyboard Module Replacement, Removing Parts: passo 10, imagem 1 %32
    • Finally, remove the keyboard module by pulling it up with the tweezers from right to left.
Conclusão
Arlind
Membro desde: 01/21/15
899 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-3, Brown Winter 2015 Membro de USF Tampa, Team 4-3, Brown Winter 2015
USFT-BROWN-W15S4G3
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 45
Ao todo: 1,033
