Ir para o conteúdo principal
Sony Xperia J Camera Replacement
O que você precisa
  1. Sony Xperia J Camera  Replacement, External Features: passo 1, imagem 1 %32
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
    Pergunte ao FixBot
    Comentar
  2. Sony Xperia J Camera  Replacement: passo 2, imagem 1 %32
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
    Pergunte ao FixBot
    Comentar
  3. Sony Xperia J Camera  Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
    Pergunte ao FixBot
    Comentar
  4. Sony Xperia J Camera  Replacement: passo 4, imagem 1 %32 Sony Xperia J Camera  Replacement: passo 4, imagem 2 %32 Sony Xperia J Camera  Replacement: passo 4, imagem 3 %32
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
    Pergunte ao FixBot
    Comentar
  5. Sony Xperia J Camera  Replacement: passo 5, imagem 1 %32 Sony Xperia J Camera  Replacement: passo 5, imagem 2 %32 Sony Xperia J Camera  Replacement: passo 5, imagem 3 %32
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
    Pergunte ao FixBot
    Comentar
  6. Sony Xperia J Camera  Replacement: passo 6, imagem 1 %32
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Sony Xperia J Camera  Replacement: passo 7, imagem 1 %32
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
    Pergunte ao FixBot
    Comentar
  8. Sony Xperia J Camera  Replacement, Removing Parts: passo 8, imagem 1 %32
    • Using the tweezers remove the clip located at the top of the phone. It should snap right off without too much pressure.
    Pergunte ao FixBot
    Comentar
  9. Sony Xperia J Camera  Replacement: passo 9, imagem 1 %32
    • Then remove the sticky pad located at the left of the phone using he tweezers.
    Pergunte ao FixBot
    Comentar
  10. Sony Xperia J Camera  Replacement, Removing Parts: passo 10, imagem 1 %32 Sony Xperia J Camera  Replacement, Removing Parts: passo 10, imagem 2 %32 Sony Xperia J Camera  Replacement, Removing Parts: passo 10, imagem 3 %32
    • Using the tweezers lift the plate out of the clamps, from left to right.
    • Then remove the whole plate off the phone.
    • The plate might be a little sticky due to the glue used when assembling the phone.
    Pergunte ao FixBot
    Comentar
  11. Sony Xperia J Camera  Replacement, Removing Parts: passo 11, imagem 1 %32
    • Using the tweezers, slowly peel the white sticker off from the top right corner to the left bottom corner.
    Pergunte ao FixBot
    Comentar
  12. Sony Xperia J Camera  Replacement, Removing Parts: passo 12, imagem 1 %32 Sony Xperia J Camera  Replacement, Removing Parts: passo 12, imagem 2 %32 Sony Xperia J Camera  Replacement, Removing Parts: passo 12, imagem 3 %32
    • Once the sticker is off, unclip the clip on the top left side(below the camera). Then slide out the wide orange cable below the clip.
    • Then lift up the board carefully and remove the clip and cable on the back.
    Pergunte ao FixBot
    Comentar
  13. Sony Xperia J Camera  Replacement, Removing the Camera: passo 13, imagem 1 %32 Sony Xperia J Camera  Replacement, Removing the Camera: passo 13, imagem 2 %32
    • Pop the camera out using your fingers, and then unclip it off the board using tweezers.
    Pergunte ao FixBot
    Comentar
Conclusão
Arlind
Membro desde: 01/21/15
899 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-3, Brown Winter 2015 Membro de USF Tampa, Team 4-3, Brown Winter 2015
USFT-BROWN-W15S4G3
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 1,014
