Introdução
If your Sony Walkman D-E356CK has issues within the device, then the disk reader will have to be removed once you've taken off the back panel. Use this guide to remove the disk reader of the Sony Walkman D-E356CK. The only tools you will need for this guide are a prying tool and a Philips head screwdriver.
O que você precisa
Open the battery compartment.
Remove the AA batteries from within the compartment.
Gently lift the motherboard to reveal the backside of the motherboard.
Disconnect the two JST connectors.
Remove the disk motor housing from front panel and flip it over.
Remove the 5mm screws from the disk motor.
Carefully take out the clear plastic piece found in the image.
Use the tweezers to carefully remove the clear yellow gear.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
