Introdução
Follow this guide to replace the ear pads on the Sony WH-1000XM4 wireless headphones.
Note: The left and right ear pads are different on this model.
O que você precisa
Place your headphones onto a work surface, ear pads facing up.
Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
Pivot the spudger down to unclip the long edge of the ear pad.
Align the cushion over the speaker and press them firmly together to snap it into place.
Press around the entire edge of the cushion, making sure all the clips have engaged.
Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
20 outras pessoas executaram este guia.
15 comentários
This is a great guide!
it is also the solution to the ticking problem on the left ear cup!
there is a small cable linking the microphone to the headset that is beneath the earcup. it has a small holder that should prevent it from moving.
if it’s not attached properly, the noise canceling will start ticking every few seconds in a very annoying way.
removing the earcup and cleaning there is the best solution I found!
Thanks a lot for the amazing guide!!
I was having a similar issue where the right ear cup was making an annoying scratching sound. Turned out to be a hair that was stuck in and brushing against the speaker. Fixed by opening and removing with tweezers!
spencer -
Very comprehensible instructions, thank you! I have rather the problem that the original ear pads are not available anywhere and are not shipped to Germany by Sony. Does anyone have a tip on how to get the replacement pads or any idea which third-party pads can be recommendet?
Where can I buy official replacement earpads?
i also need to know that, i found some OEM on amazon, but i don't trust any of them
