Introdução
Use this guide to remove or replace the earcup cushions on your Sony WH-1000XM3 headphones.
O que você precisa
Before beginning any repairs, turn off your headphones.
Insert a spudger into the gap between the earcup cushion and the earcup frame.
Pry up the earcup cushion by tilting the spudger downwards to release the plastic clips.
Repeat the previous step around the perimeter of the earcup cushion to release the remaining clips.
16 outras pessoas executaram este guia.
2 comentários
Bedankt! Net even nodig. Instructies pads erg summier en uitgebreide handleiding Sony staat het niet in. Wilde niet mijn fijne koptelefoon kapotmaken!
